ExtLine1Point 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 1038| 评论: 0|原作者: admin|来自: AutoCAD
指定延长线 1 的原点。
object.ExtLine1Point
类型:DimAligned、DimArcLength
此属性应用于的对象。
只读:不
类型:变体(双打的三元素阵列)
表示第一条延伸线原点的 3D 坐标。
对齐尺寸的尺寸线将平行于连接延伸线 1 和 2 原点的线。
要标注尺寸的线
创建的维度
Sub Example_ExtLine1Point()
    ' This example creates an aligned dimension and then changes the
    ' ExtLine1Point property for that dimension.
    Dim dimObj As AcadDimAligned
    Dim point1(0 To 2) As Double
    Dim point2(0 To 2) As Double
    ' Define the dimension
    point1(0) = 5#: point1(1) = 5#: point1(2) = 0#
    point2(0) = 10#: point2(1) = 5#: point2(2) = 0#
    location(0) = 5#: location(1) = 7#: location(2) = 0#
    ZoomAll
    MsgBox "The current value for ExtLine1Point is " & dimObj.ExtLine1Point(0) & ", " & dimObj.ExtLine1Point(1) & ", " & dimObj.ExtLine1Point(2), vbInformation, "ExtLine1Point Example"
    ' Change the endpoint of the first extension line
    point1(0) = 2: point1(1) = 5: point1(2) = 0
    dimObj.ExtLine1Point = point1
    dimObj.Update
    ' Return the endpoint of the first extension line
    ' Note that the return value is a Variant
    Dim retPnt As Variant
    retPnt = dimObj.ExtLine1Point
    MsgBox "The new value for ExtLine1Point is " & dimObj.ExtLine1Point(0) & ", " & dimObj.ExtLine1Point(1) & ", " & dimObj.ExtLine1Point(2), vbInformation, "ExtLine1Point Example"
(defun c:Example_ExtLine1Point()
    ;; This example creates an aligned dimension and then changes the
    ;; ExtLine1Point property for that dimension.
    ;; Define the dimension
          point2 (vlax-3d-point 10 5 0)
    (vla-ZoomAll acadObj)
    (setq extLinePoint (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1Point dimObj))))
    (alert (strcat "The current value for ExtLine1Point is " (rtos (nth 0 extLinePoint) 2) ", "
		                                             (rtos (nth 1 extLinePoint) 2) ", "
		                                             (rtos (nth 2 extLinePoint) 2)))
    ;; Change the endpoint of the first extension line
    (setq point1 (vlax-3d-point 2 5 0))
    (vla-put-ExtLine1Point dimObj point1)
    (vla-Update dimObj)
    ;; Return the endpoint of the first extension line
    ;; Note that the return value is a Variant
    (setq retPnt (vlax-safearray->list (vlax-variant-value (vla-get-ExtLine1Point dimObj))))
    (alert (strcat "The new value for ExtLine1Point is " (rtos (nth 0 retPnt) 2) ", "
		                                         (rtos (nth 1 retPnt) 2) ", "
		                                         (rtos (nth 2 retPnt) 2)))
GMT+8, 2026-10-27 19:26
