ExtensionLineOffset 属性 (ActiveX)
指定延伸线与原点的偏移距离。 支持的平台:仅限 Windows 签名VBA: object.ExtensionLineOffset
属性值只读:不 类型:双 一个正实数,指定将延伸线偏移到原点之外的距离。 言论此属性的初始值为 0.0625。 注意:此属性将覆盖给定维度的 DIMEXO 系统变量的值。
例子VBA: Sub Example_ExtensionLineOffset()
' This example creates a Dim3PointAngular object in model space
' and changes the offset of the extension lines using the
' ExtensionLineOffset property
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Read and display current offset of the extension lines from the control points
MsgBox "The extension lines are currently offset " & DimPointAngularObj.ExtensionLineOffset & " units"
' Change the extension lines offset distance from the control points
DimPointAngularObj.ExtensionLineOffset = 1.5
MsgBox "The extension lines are now offset " & DimPointAngularObj.ExtensionLineOffset & " units"
可视化 LISP: (vl-load-com)
(defun c:Example_ExtensionLineOffset()
;; This example creates a Dim3PointAngular object in model space
;; and changes the offset of the extension lines using the
;; ExtensionLineOffset property
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Read and display current offset of the extension lines from the control points
(alert (strcat "The extension lines are currently offset " (rtos (vla-get-ExtensionLineOffset DimPointAngularObj) 2) " units"))
;; Change the extension lines offset distance from the control points
(vla-put-ExtensionLineOffset DimPointAngularObj 1.5)
(alert (strcat "The extension lines are now offset " (rtos (vla-get-ExtensionLineOffset DimPointAngularObj) 2) " units"))
GMT+8, 2026-10-28 01:27
