ExtensionLineColor 属性 (ActiveX)
指定尺寸延伸线的颜色。 支持的平台:仅限 Windows 签名VBA: object.ExtensionLineColor
属性值只读:不 类型:枚举acColor 使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:
言论可以将颜色设置为从 0 到 256 的数字索引值并读取。为标准七种颜色以及 BYBLOCK 和 BYLAYER 名称提供了常量。 如果使用 ,AutoCAD 将以默认颜色(白色或黑色,具体取决于您的配置)绘制新对象,直到它们被分组到块中。在图形中插入块时,块中的对象将继承颜色属性的当前设置。acByBlock 如果使用 ,则新对象将采用绘制它们的图层的颜色。acByLayer 注意:此属性将覆盖给定维度对象的 DIMCLRE 系统变量的值。
例子VBA: Sub Example_ExtensionLineColor()
' This example creates a Dim3PointAngular object in model space
' and changes the extension line color to red using the ExtensionLineColor property
Dim DimPointAngularObj As AcadDim3PointAngular
Dim AngleVertex(0 To 2) As Double
Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
Dim TextPoint(0 To 2) As Double
' Define the new Dim3PointAngular object
AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
' Create the new Dim3PointAngular object in model space
Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
' Read and display current dimension line color
MsgBox "The extension line color for this object is currently set to: " & DimPointAngularObj.ExtensionLineColor
' Change the extension line color
DimPointAngularObj.ExtensionLineColor = acRed
' Read and display current extension line color
MsgBox "The extension line color for this object is now set to: " & DimPointAngularObj.ExtensionLineColor & " (Red)"
可视化 LISP: (vl-load-com)
(defun c:Example_ExtensionLineColor()
;; This example creates a Dim3PointAngular object in model space
;; and changes the extension line color to red using the ExtensionLineColor property
;; Define the new Dim3PointAngular object
(setq AngleVertex (vlax-3d-point 0 0 0)
FirstPoint (vlax-3d-point 2 2 0)
SecondPoint (vlax-3d-point 1 4 0)
TextPoint (vlax-3d-point 6 6 0))
;; Create the new Dim3PointAngular object in model space
(setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
(vla-ZoomAll acadObj)
;; Read and display current dimension line color
(alert (strcat "The extension line color for this object is currently set to: " (itoa (vla-get-ExtensionLineColor DimPointAngularObj))))
;; Change the extension line color
(vla-put-ExtensionLineColor DimPointAngularObj acRed)
;; Read and display current extension line color
(alert (strcat "The extension line color for this object is now set to: " (itoa (vla-get-ExtensionLineColor DimPointAngularObj)) " (Red)"))
GMT+8, 2026-10-27 19:21
