EnableStartupDialog 属性 (ActiveX)
指定在启动 AutoCAD 或创建新图形时是否显示启动对话框。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 当 EnableStartupDialog 为 时,可以显示传统的启动对话框。True 例子VBA: Sub Example_EnableStartupDialog()
' EnableStartupDialog. It then changes the value, and finally
Dim currEnableStartupDialog As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current EnableStartupDialog value
currEnableStartupDialog = preferences.System.EnableStartupDialog
MsgBox "The current value for EnableStartupDialog is " & preferences.System.EnableStartupDialog, vbInformation, "EnableStartupDialog Example"
' Change the value for EnableStartupDialog
preferences.System.EnableStartupDialog = Not (currEnableStartupDialog)
MsgBox "The new value for EnableStartupDialog is " & preferences.System.EnableStartupDialog, vbInformation, "EnableStartupDialog Example"
' Reset EnableStartupDialog to its original value
preferences.System.EnableStartupDialog = currEnableStartupDialog
MsgBox "The EnableStartupDialog value is reset to " & preferences.System.EnableStartupDialog, vbInformation, "EnableStartupDialog Example"
可视化 LISP: (vl-load-com)
(defun c:Example_EnableStartupDialog()
;; EnableStartupDialog. It then changes the value, and finally
;; Get the system preferences object
(setq ACADPref (vla-get-System preferences))
;; Retrieve the current EnableStartupDialog value
(setq currEnableStartupDialog (vla-get-EnableStartupDialog ACADPref))
(alert (strcat "The current value for EnableStartupDialog is " (if (= currEnableStartupDialog :vlax-true) "True" "False")))
;; Change the value for EnableStartupDialog
(vla-put-EnableStartupDialog ACADPref (if (= currEnableStartupDialog :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-EnableStartupDialog ACADPref))
(alert (strcat "The new value for EnableStartupDialog is " (if (= newValue :vlax-true) "True" "False")))
;; Reset EnableStartupDialog to its original value
(vla-put-EnableStartupDialog ACADPref currEnableStartupDialog)
(alert (strcat "The EnableStartupDialog value is reset to " (if (= currEnableStartupDialog :vlax-true) "True" "False")))
GMT+8, 2026-10-30 11:59
