ElevationModelSpace 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 981| 评论: 0|原作者: admin|来自: AutoCAD
指定模型空间中的高程设置。
object.ElevationModelSpace
类型:数据库、文档
此属性应用于的对象。
只读:不
类型:双
模型空间的高程设置。
当前高程是每当需要 3D 点但仅提供 X 和 Y 值时使用的 Z 值。当前高程分别在模型空间和图纸空间中维护。
Sub Example_ElevationModelSpace()
    ' This example changes the model space elevation of the current drawing
    ' and then resets it to the original value again.
    Dim currElevation As Double
    currElevation = ThisDrawing.ElevationModelSpace
    MsgBox "The current model space elevation is " & ThisDrawing.ElevationModelSpace, vbInformation, "ElevationModelSpace Example"
    ' Change the elevation
    ThisDrawing.ElevationModelSpace = currElevation + 2
    MsgBox "The new model space elevation is " & ThisDrawing.ElevationModelSpace, vbInformation, "ElevationModelSpace Example"
    ' Reset the elevation to its original value
    MsgBox "The model space elevation is reset to " & ThisDrawing.ElevationModelSpace, vbInformation, "ElevationModelSpace Example"
(defun c:Example_ElevationModelSpace()
    ;; This example changes the model space elevation of the current drawing
    ;; and then resets it to the original value again.
    (setq currElevation (vla-get-ElevationModelSpace doc))
    (alert (strcat "The current model space elevation is " (rtos currElevation 2)))
    ;; Change the elevation
    (vla-put-ElevationModelSpace doc (+ currElevation 2))
    (alert (strcat "The new model space elevation is " (rtos (vla-get-ElevationModelSpace doc) 2)))
    ;; Reset the elevation to its original value
    (vla-put-ElevationModelSpace doc currElevation)
    (alert (strcat "The model space elevation is reset to " (rtos (vla-get-ElevationModelSpace doc) 2)))
GMT+8, 2026-10-27 15:09
