DogLegged 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 588| 评论: 0|原作者: admin|来自: AutoCAD
狗腿的状态。
object.DogLegged
类型:MLeader
此属性应用于的对象。
只读:不
类型:布尔
  • True:启用水平着陆。
  • False:水平着陆被禁用。
Sub Example_DogLeg()
    Dim oML As AcadMLeader
    Dim points(0 To 14) As Double
    ' Define the leader points
    points(0) = 1: points(1) = 1: points(2) = 0
    points(3) = 1: points(4) = 2: points(5) = 0
    points(6) = 2: points(7) = 2: points(8) = 0
    points(9) = 3: points(10) = 2: points(11) = 0
    points(12) = 4: points(13) = 4: points(14) = 0
    Dim i As Long
    Set oML = ThisDrawing.ModelSpace.AddMLeader(points, i)
    oML.DogLegged = True
    oML.DoglegLength = 1.3
    MsgBox "The dog-leg length is  " & oML.DoglegLength
    ZoomAll
(defun c:Example_DogLeg()
    ;; Define the leader points
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 14)))
    (vlax-safearray-fill points '(1 1 0
				                              1 2 0
				                              2 2 0
				                              3 2 0
				                              4 4 0
    (setq i 0)
    (setq oML (vla-AddMLeader modelSpace points i))
    (vla-put-DogLegged oML :vlax-true)
    (vla-put-DoglegLength oML 1.3)
    (alert (strcat "The dog-leg length is " (rtos (vla-get-DoglegLength oML) 2)))
    (vla-ZoomAll acadObj)
GMT+8, 2026-10-28 01:33
