Documents 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 778| 评论: 0|原作者: admin|来自: AutoCAD
获取 Documents 集合。
object.Documents
类型: 应用
此属性应用于的对象。
只读:是的
类别: 文档
当前 AutoCAD 进程的集合。Documents
该集合允许您访问当前 AutoCAD 任务中的所有文档或图形。Documents
Sub Example_Documents()
    ' This example obtains a reference to the Documents collection
    ' and displays information about the loaded documents.
    Dim Document As AcadDocument
    Dim msg As String
    msg = vbCrLf
    ' Cycle through the Documents collection and retrieve the names
    ' of the loaded documents
    For Each Document In Documents
        msg = msg & Document.Name & vbCrLf
    Next
    ' Display loaded document information
    If Documents.Count > 0 Then
        MsgBox "The loaded documents are: " & msg
    Else
        MsgBox "There are no loaded documents!"
    End If
(defun c:Example_Documents()
    ;; This example obtains a reference to the Documents collection
    ;; and displays information about the loaded documents.
    ;; Cycle through the Documents collection and retrieve the names
    ;; of the loaded documents
    (setq msg "")
    (vlax-for Document (vla-get-Documents acadObj)
        (setq msg (strcat msg "\n" (vla-get-Name Document)))
    ;; Display loaded document information
    (if (> (vla-get-Count (vla-get-Documents acadObj)))
        (alert (strcat "The loaded documents are: " msg))
        (alert "There are no loaded documents!")
GMT+8, 2026-10-28 03:26
