Document 属性 (ActiveX)
获取对象所属的文档(绘图)。 支持的平台:仅限 Windows 签名VBA: object.Document 言论没有其他评论。 例子VBA: Sub Example_Document()
' This example creates a circle in model space and then
' finds the name of the document that the circle resides in.
Dim circleObj As AcadCircle
Dim radius As Double
' Define the circle
centerPoint(0) = 0#: centerPoint(1) = 0#: centerPoint(2) = 0#
radius = 5#
' Create the Circle object in model space
Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
ZoomAll
' Find the document name for the circle
Dim currDoc As AcadDocument
Set currDoc = circleObj.Document
MsgBox "The circle resides in: " & currDoc.name
可视化 LISP: (vl-load-com)
(defun c:Example_Document()
;; This example creates a circle in model space and then
;; finds the name of the document that the circle resides in.
;; Define the circle
(setq centerPoint (vlax-3d-point 0 0 0)
radius 5)
;; Create the Circle object in model space
(setq circleObj (vla-AddCircle modelSpace centerPoint radius))
(vla-ZoomAll acadObj)
;; Find the document name for the circle
(setq currDoc (vla-get-Document circleObj))
(alert (strcat "The circle resides in: " (vla-get-Name currDoc)))
GMT+8, 2026-10-27 23:49
