DockedVisibleLines 属性 (ActiveX)
指定要在命令窗口中显示的文本行数。(已过时) 支持的平台:仅限 Windows 属性值只读:不 类型:整数 一个正整数,表示要在命令窗口中显示的文本行数。 言论没有其他评论。 例子VBA: Sub Example_DockedVisibleLines()
' DockedVisibleLines. It then changes the value, and finally
Dim currDockedVisibleLines As Integer
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current DockedVisibleLines value
currDockedVisibleLines = preferences.Display.DockedVisibleLines
MsgBox "The current value for DockedVisibleLines is " & preferences.DISPLAY.DockedVisibleLines, vbInformation, "DockedVisibleLines Example"
' Change the value for DockedVisibleLines
preferences.Display.DockedVisibleLines = 15
MsgBox "The new value for DockedVisibleLines is " & preferences.DISPLAY.DockedVisibleLines, vbInformation, "DockedVisibleLines Example"
' Reset DockedVisibleLines to its original value
preferences.Display.DockedVisibleLines = currDockedVisibleLines
MsgBox "The DockedVisibleLines value is reset to " & preferences.Display.DockedVisibleLines, vbInformation, "DockedVisibleLines Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DockedVisibleLines()
;; DockedVisibleLines. It then changes the value, and finally
;; Get the Display preferences object
(setq ACADPref (vla-get-Display preferences))
;; Retrieve the current DockedVisibleLines value
(setq currDockedVisibleLines (vla-get-DockedVisibleLines ACADPref))
(alert (strcat "The current value for DockedVisibleLines is " (itoa currDockedVisibleLines)))
;; Change the value for DockedVisibleLines
(setq newValue 15)
(vla-put-DockedVisibleLines ACADPref newValue)
(alert (strcat "The new value for DockedVisibleLines is " (itoa newValue)))
;; Reset DockedVisibleLines to its original value
(vla-put-DockedVisibleLines ACADPref currDockedVisibleLines)
(alert (strcat "The DockedVisibleLines value is reset to " (itoa currDockedVisibleLines)))
GMT+8, 2026-10-26 14:27
