DisplaySilhouette 属性 (ActiveX)
控制实体对象的轮廓曲线是否在线框模式下显示。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性的值存储在 DISPSILH 系统变量中。
例子VBA: Sub Example_DisplaySilhouette()
' DisplaySilhouette. It then changes the value, and finally
Dim currDisplaySilhouette As Boolean
' Retrieve the current DisplaySilhouette value
currDisplaySilhouette = ThisDrawing.Preferences.DisplaySilhouette
MsgBox "The current value for DisplaySilhouette is " & preferences.DisplaySilhouette, vbInformation, "DisplaySilhouette Example"
' Change the value for DisplaySilhouette
ThisDrawing.Preferences.DisplaySilhouette = Not (currDisplaySilhouette)
MsgBox "The new value for DisplaySilhouette is " & preferences.DisplaySilhouette, vbInformation, "DisplaySilhouette Example"
' Reset DisplaySilhouette to its original value
ThisDrawing.Preferences.DisplaySilhouette = currDisplaySilhouette
MsgBox "The DisplaySilhouette value is reset to " & preferences.DisplaySilhouette, vbInformation, "DisplaySilhouette Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DisplaySilhouette()
;; DisplaySilhouette. It then changes the value, and finally
(setq preferences (vla-get-Preferences doc))
;; Retrieve the current DisplaySilhouette value
(setq currDisplaySilhouette (vla-get-DisplaySilhouette preferences))
(alert (strcat "The current value for DisplaySilhouette is " (if (= currDisplaySilhouette :vlax-true) "True" "False")))
;; Change the value for DisplaySilhouette
(setq newValue (if (= currDisplaySilhouette :vlax-true) :vlax-false :vlax-true))
(vla-put-DisplaySilhouette preferences newValue)
(alert (strcat "The new value for DisplaySilhouette is " (if (= newValue :vlax-true) "True" "False")))
;; Reset DisplaySilhouette to its original value
(vla-put-DisplaySilhouette preferences currDisplaySilhouette)
(alert (strcat "The DisplaySilhouette value is reset to " (if (= currDisplaySilhouette :vlax-true) "True" "False")))
GMT+8, 2026-10-28 09:54
