DisplayScrollBars 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 738| 评论: 0|原作者: admin|来自: AutoCAD
指定是否在绘图窗口的底部和右侧显示滚动条。
object.DisplayScrollBars
类型:首选项显示
此属性应用于的对象。
只读:
类型:布尔
  • True:显示滚动条。
  • False:不显示滚动条。
此属性的初始值为 。False
Sub Example_DisplayScrollBars()
    ' DisplayScrollBars. It then changes the value, and finally
    Dim currDisplayScrollBars As Boolean
    Set preferences = ThisDrawing.Application.Preferences
    ' Retrieve the current DisplayScrollBars value
    currDisplayScrollBars = preferences.Display.DisplayScrollBars
    MsgBox "The current value for DisplayScrollBars is " & preferences.DISPLAY.DisplayScrollBars, vbInformation, "DisplayScrollBars Example"
    ' Change the value for DisplayScrollBars
    preferences.DISPLAY.DisplayScrollBars = Not (currDisplayScrollBars)
    MsgBox "The new value for DisplayScrollBars is " & preferences.DISPLAY.DisplayScrollBars, vbInformation, "DisplayScrollBars Example"
    ' Reset DisplayScrollBars to its original value
    preferences.DISPLAY.DisplayScrollBars = currDisplayScrollBars
    MsgBox "The DisplayScrollBars value is reset to " & preferences.DISPLAY.DisplayScrollBars, vbInformation, "DisplayScrollBars Example"
(defun c:Example_DisplayScrollBars()
    ;; DisplayScrollBars. It then changes the value, and finally
    ;; Get the Display preferences object
    (setq ACADPref (vla-get-Display preferences))
    ;; Retrieve the current DisplayScrollBars value
    (setq currDisplayScrollBars (vla-get-DisplayScrollBars ACADPref))
    (alert (strcat "The current value for DisplayScrollBars is " (if (= currDisplayScrollBars :vlax-true) "True" "False")))
    ;; Change the value for DisplayScrollBars
    (setq newValue (if (= currDisplayScrollBars :vlax-true) :vlax-false :vlax-true))
    (vla-put-DisplayScrollBars ACADPref newValue)
    (alert (strcat "The new value for DisplayScrollBars is " (if (= newValue :vlax-true) "True" "False")))
    ;; Reset DisplayScrollBars to its original value
    (vla-put-DisplayScrollBars ACADPref currDisplayScrollBars)
    (alert (strcat "The DisplayScrollBars value is reset to " (if (= currDisplayScrollBars :vlax-true) "True" "False")))
GMT+8, 2026-9-13 02:44
