DisplayScreenMenu 属性 (ActiveX)
指定是否在绘图窗口的右侧显示屏幕菜单。(已过时) 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 例子VBA: Sub Example_DisplayScreenMenu()
' DisplayScreenMenu. It then changes the value, and finally
Dim currDisplayScreenMenu As Boolean
Set preferences = ThisDrawing.Application.Preferences
' Retrieve the current DisplayScreenMenu value
currDisplayScreenMenu = preferences.Display.DisplayScreenMenu
MsgBox "The current value for DisplayScreenMenu is " & preferences.DISPLAY.DisplayScreenMenu, vbInformation, "DisplayScreenMenu Example"
' Change the value for DisplayScreenMenu
preferences.DISPLAY.DisplayScreenMenu = Not (currDisplayScreenMenu)
MsgBox "The new value for DisplayScreenMenu is " & preferences.DISPLAY.DisplayScreenMenu, vbInformation, "DisplayScreenMenu Example"
' Reset DisplayScreenMenu to its original value
preferences.DISPLAY.DisplayScreenMenu = currDisplayScreenMenu
MsgBox "The DisplayScreenMenu value is reset to " & preferences.DISPLAY.DisplayScreenMenu, vbInformation, "DisplayScreenMenu Example"
可视化 LISP: (vl-load-com)
(defun c:Example_DisplayScreenMenu()
;; DisplayScreenMenu. It then changes the value, and finally
;; Get the Display preferences object
(setq ACADPref (vla-get-Display preferences))
;; Retrieve the current DisplayScreenMenu value
(setq currDisplayScreenMenu (vla-get-DisplayScreenMenu ACADPref))
(alert (strcat "The current value for DisplayScreenMenu is " (if (= currDisplayScreenMenu :vlax-true) "True" "False")))
;; Change the value for DisplayScreenMenu
(setq newValue (if (= currDisplayScreenMenu :vlax-true) :vlax-false :vlax-true))
(vla-put-DisplayScreenMenu ACADPref newValue)
(alert (strcat "The new value for DisplayScreenMenu is " (if (= newValue :vlax-true) "True" "False")))
;; Reset DisplayScreenMenu to its original value
(vla-put-DisplayScreenMenu ACADPref currDisplayScreenMenu)
(alert (strcat "The DisplayScreenMenu value is reset to " (if (= currDisplayScreenMenu :vlax-true) "True" "False")))
GMT+8, 2026-10-28 09:03
