DisplayLayoutTabs 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 812| 评论: 0|原作者: admin|来自: AutoCAD
指定是否在绘图编辑器中显示“模型”和“布局”选项卡。
object.DisplayLayoutTabs
类型:首选项显示
此属性应用于的对象。
只读:不
类型:布尔
  • True:显示“模型”(Model) 和“布局”(layout) 选项卡。
  • False:不显示“模型”(Model) 和“布局”(layout) 选项卡。
此属性的初始值为 。True
Sub Example_DisplayLayoutTabs()
    ' This example reads and modifies the preference value that controls
    ' the display of the Model and layout tabs. When finished, this example
    ' resets the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.DISPLAY
    originalValue = ACADPref.DisplayLayoutTabs
    MsgBox "The DisplayLayoutTabs preference is set to: " & originalValue
    ' Modify the DisplayLayoutTabs preference by toggling the value
    ACADPref.DisplayLayoutTabs = Not (originalValue)
    newValue = ACADPref.DisplayLayoutTabs
    MsgBox "The DisplayLayoutTabs preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.DisplayLayoutTabs = originalValue
    MsgBox "The DisplayLayoutTabs preference was reset back to: " & originalValue
(defun c:Example_DisplayLayoutTabs()
    ;; This example reads and modifies the preference value that controls
    ;; the display of the Model and layout tabs. When finished, this example
    ;; resets the preference value back to its original value.
    ;; Get the display preferences object
    (setq ACADPref (vla-get-Display preferences))
    (setq originalValue (vla-get-DisplayLayoutTabs ACADPref))
    (alert (strcat "The DisplayLayoutTabs preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the DisplayLayoutTabs preference by toggling the value
    (vla-put-DisplayLayoutTabs ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-DisplayLayoutTabs ACADPref))
    (alert (strcat "The DisplayLayoutTabs preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-DisplayLayoutTabs ACADPref originalValue)
    (alert (strcat "The DisplayLayoutTabs preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-11-16 15:07
