DisplayGrips 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 807| 评论: 0|原作者: admin|来自: AutoCAD
控制“拉伸”、“移动”、“旋转”、“缩放”和“镜像”夹持模式的选择集夹点的显示。
object.DisplayGrips
类型:首选项选择
此属性应用于的对象。
只读:不
类型:布尔
  • True:显示手柄。
  • False:不显示握把。
此属性的初始值为 。True
若要调整夹点的大小和光标在捕捉到夹点时使用的有效选择区域,请使用该属性。GripSize
要调整选定或未选定夹点的颜色,请使用 or 属性。GripColorSelectedGripColorUnselected
注意:此属性的值存储在 GRIPS 系统变量中。
Sub Example_DisplayGrips()
    ' This example reads and modifies the preference value that controls
    ' the display of selection set grips for the Stretch, Move, Rotate,
    ' Scale, and Mirror grip modes.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesSelection
    ' Get the selection preferences object
    Set ACADPref = ThisDrawing.Application.Preferences.Selection
    originalValue = ACADPref.DisplayGrips
    MsgBox "The DisplayGrips preference is set to: " & originalValue
    ' Modify the DisplayGrips preference by toggling the value
    ACADPref.DisplayGrips = Not (originalValue)
    newValue = ACADPref.DisplayGrips
    MsgBox "The DisplayGrips preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.DisplayGrips = originalValue
    MsgBox "The DisplayGrips preference was reset back to: " & originalValue
(defun c:Example_DisplayGrips()
    ;; This example reads and modifies the preference value that controls
    ;; the display of selection set grips for the Stretch, Move, Rotate,
    ;; Scale, and Mirror grip modes.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the selection preferences object
    (setq ACADPref (vla-get-Selection preferences))
    (setq originalValue (vla-get-DisplayGrips ACADPref))
    (alert (strcat "The DisplayGrips preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
    ;; Modify the DisplayGrips preference by toggling the value
    (vla-put-DisplayGrips ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
    (setq newValue (vla-get-DisplayGrips ACADPref))
    (alert (strcat "The DisplayGrips preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
    ;;         this preference in effect
    (vla-put-DisplayGrips ACADPref originalValue)
    (alert (strcat "The DisplayGrips preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-28 21:05
