DimLineInside 属性 (ActiveX)
仅指定延伸线内尺寸线的显示。 支持的平台:仅限 Windows 签名VBA: object.DimLineInside
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性将覆盖给定维度的 DIMSOXD 系统变量的值。
例子VBA: Sub Example_DimLineInside()
' This example creates a DimAligned object in model space
' and toggles the dimension lines to be both allowed and disallowed
' outside the extension lines
Dim dimObj As AcadDimAligned
Dim CurrentValue As String
' Define the dimension
point2(0) = 6: point2(1) = 5: point2(2) = 0
' Read and display current line suppression information
CurrentValue = IIf(dimObj.DimLineInside, "are not", "are")
MsgBox "Dimension lines " & CurrentValue & " allowed outside the extension lines"
' Suppress the display of dimension lines outside the extension lines
dimObj.DimLineInside = True
MsgBox "Dimension lines are not allowed outside the extension lines"
' Allow the display of dimension lines outside the extension lines (default)
dimObj.DimLineInside = False
MsgBox "Dimension lines are allowed outside the extension lines"
可视化 LISP: (vl-load-com)
(defun c:Example_DimLineInside()
;; This example creates a DimAligned object in model space
;; and toggles the dimension lines to be both allowed and disallowed
;; outside the extension lines
;; Define the dimension
point2 (vlax-3d-point 6 5 0)
(vla-ZoomAll acadObj)
;; Read and display current line suppression information
(setq CurrentValue (if (= (vla-get-DimLineInside dimObj) :vlax-true) "are not" "are"))
(alert (strcat "Dimension lines " CurrentValue " allowed outside the extension lines"))
;; Suppress the display of dimension lines outside the extension lines
(vla-put-DimLineInside dimObj :vlax-true)
(alert "Dimension lines are not allowed outside the extension lines")
;; Allow the display of dimension lines outside the extension lines (default)
(vla-put-DimLineInside dimObj :vlax-false)
(alert "Dimension lines are allowed outside the extension lines")
GMT+8, 2026-10-28 04:53
