DimensionLineWeight 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 801| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸线的线宽。
object.DimensionLineWeight
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimRadial、DimRadialLarge、DimRotated、Leader
此属性应用于的对象。
只读:不
类型:枚举acLineWeight
  • acLnWtByLayer
  • acLnWtByBlock
  • acLnWtByLwDefault
  • acLnWt000
  • acLnWt005
  • acLnWt009
  • acLnWt013
  • acLnWt015
  • acLnWt018
  • acLnWt020
  • acLnWt025
  • acLnWt030
  • acLnWt035
  • acLnWt040
  • acLnWt050
  • acLnWt053
  • acLnWt060
  • acLnWt070
  • acLnWt080
  • acLnWt090
  • acLnWt100
  • acLnWt106
  • acLnWt120
  • acLnWt140
  • acLnWt158
  • acLnWt200
  • acLnWt211
此属性的初始值为 。acLnWtByBlock
仅当属性设置为 时,线宽设置才可见。LineweightDisplayTrue
Sub Example_DimensionLineWeight()
    ' This example creates a Dim3PointAngular object in model space
    ' and changes the dimension lineweight to a thicker value
    ' using the DimensionLineWeight property
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    Dim oldLWSetting As Boolean
    Dim CurrentSetting As String
    ' Turn on lineweight display so the changes can be seen
    oldLWSetting = ThisDrawing.preferences.LineWeightDisplay
    ThisDrawing.preferences.LineWeightDisplay = True
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current dimension lineweight
    CurrentSetting = DimPointAngularObj.DimensionLineWeight
    Select Case CurrentSetting
        Case acLnWtByLayer: CurrentSetting = "ByLayer"
        Case acLnWtByBlock: CurrentSetting = "ByBlock"
        Case acLnWtByLwDefault: CurrentSetting = "ByDefault"
        Case Else
    End Select
    MsgBox "The dimension lineweight setting for this object is currently set to: " & CurrentSetting
    ' Change the dimension lineweight
    DimPointAngularObj.DimensionLineWeight = acLnWt100
    MsgBox "The dimension lineweight setting for this object is now set to: " & DimPointAngularObj.DimensionLineWeight
    ' Return previous lineweight setting
    ThisDrawing.preferences.LineWeightDisplay = oldLWSetting
(defun c:Example_DimensionLineWeight()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and changes the dimension lineweight to a thicker value
    ;; using the DimensionLineWeight property
    (setq preferences (vla-get-Preferences doc))
    ;; Turn on lineweight display so the changes can be seen
    (setq oldLWSetting (vla-get-LineWeightDisplay preferences))
    (vla-put-LineWeightDisplay preferences :vlax-true)
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current dimension lineweight
    (setq CurrentSetting (vla-get-DimensionLineWeight DimPointAngularObj))
    (cond
        ((= acLnWtByLayer CurrentSetting)(setq CurrentSetting "ByLayer"))
        ((= acLnWtByBlock CurrentSetting)(setq CurrentSetting "ByBlock"))
        ((= acLnWtByLwDefault CurrentSetting)(setq CurrentSetting "ByDefault"))
	(setq CurrentSetting (itoa CurrentSetting))
    (alert (strcat "The dimension lineweight setting for this object is currently set to: " CurrentSetting))
    ;; Change the dimension lineweight
    (vla-put-DimensionLineWeight DimPointAngularObj acLnWt100)
    (alert (strcat "The dimension lineweight setting for this object is now set to: " (itoa (vla-get-DimensionLineWeight DimPointAngularObj))))
    ;; Return previous lineweight setting
    (vla-put-DimensionLineWeight DimPointAngularObj oldLWSetting)
GMT+8, 2026-10-26 18:20
