Dictionaries 属性 (ActiveX)
获取文档的 Dictionaries 集合。 支持的平台:仅限 Windows 言论没有其他评论。 例子VBA: Sub Example_Dictionaries()
' This example finds the current dictionary collection and
' adds a new dictionary to that collection.
Dim dict As AcadDictionary
Set dict = ThisDrawing.Dictionaries.Add("TEST")
MsgBox "A new dictionary called " & dict.name & " has been added to the dictionaries collection.", vbInformation, "Dictionaries Example"
可视化 LISP: (vl-load-com)
(defun c:Example_Dictionaries()
;; This example finds the current dictionary collection and
;; adds a new dictionary to that collection.
(setq dict (vla-Add (vla-get-Dictionaries doc) "TEST"))
(alert (strcat "A new dictionary called " (vla-get-Name dict) " has been added to the dictionaries collection."))
GMT+8, 2026-11-15 11:58
