Diameter 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 713| 评论: 0|原作者: admin|来自: AutoCAD
指定圆的直径。
object.Diameter
类型:圆形
此属性应用于的对象。
只读:不
类型:双
圆的直径。
Sub Example_Diameter()
    ' This example creates a Circle object in model space and
    ' returns the diameter of the new Circle
    Dim circleObj As AcadCircle
    Dim radius As Double
    ' Define the new Circle object
    centerPoint(0) = 0: centerPoint(1) = 0: centerPoint(2) = 0
    radius = 5#
    ' Create the Circle object in model space
    Set circleObj = ThisDrawing.ModelSpace.AddCircle(centerPoint, radius)
    MsgBox "The diameter of the new Circle is: " & circleObj.Diameter
(defun c:Example_Diameter()
    ;; This example creates a Circle object in model space and
    ;; returns the diameter of the new Circle
    ;; Define the new Circle object
    (setq centerPoint (vlax-3d-point 0 0 0)
          radius 5)
    ;; Create the Circle object in model space
    (setq circleObj (vla-AddCircle modelSpace centerPoint radius))
    (vla-ZoomAll acadObj)
    (alert (strcat "The diameter of the new Circle is: " (rtos (vla-get-Diameter circleObj) 2)))
GMT+8, 2026-10-27 20:41
