CustomScale 属性 (ActiveX)
指定视口的自定义比例因子。 支持的平台:仅限 Windows 属性值只读:不 类型:双 视口的自定义比例因子。 言论若要将视口设置为自定义比例,请先将属性设置为 ,然后使用此属性定义自定义比例值。StandardScaleacVpCustomScale 例子VBA: Sub Example_CustomScale()
' This example adds a line in paper space, creates a new paper space viewport, and cycles through some common paper space custom scale sizes
' for the new paper space viewport
Dim lineObj As AcadLine
Dim PViewPort As AcadPViewport
Dim startPoint(0 To 2) As Double, endPoint(0 To 2) As Double
Dim center(0 To 2) As Double
Dim width As Double, height As Double
' Define the start and end points for the line
startPoint(0) = 1: startPoint(1) = 1: startPoint(2) = 0
endPoint(0) = 5: endPoint(1) = 5: endPoint(2) = 0
' Define the paper space viewport
center(0) = 3: center(1) = 3: center(2) = 0
width = 40: height = 40
' Create the line in paper space
Set lineObj = ThisDrawing.PaperSpace.AddLine(startPoint, endPoint)
' Create the paper space viewport
Set PViewPort = ThisDrawing.PaperSpace.AddPViewport(center, width, height)
' Set the paper space viewport scale to custom
PViewPort.StandardScale = acVpCustomScale
' Change from model space to paper space
ThisDrawing.ActiveSpace = acPaperSpace
' Read and display the existing paper space viewport scale setting
MsgBox "The scale of the new PViewport is: " & PViewPort.CustomScale
' Change the custom scale setting to 1:10 scale
PViewPort.CustomScale = 0.1
' Read and display the new paper space viewport scale setting
MsgBox "The scale of the new PViewport has been changed to: " & PViewPort.CustomScale
可视化 LISP: (vl-load-com)
(defun c:Example_CustomScale()
;; This example adds a line in paper space, creates a new paper space viewport, and cycles through some common paper space custom scale sizes
;; for the new paper space viewport
;; Define the start and end points for the line
(setq startPoint (vlax-3d-point 1 1 0)
endPoint (vlax-3d-point 5 5 0))
;; Define the paper space viewport
(setq center (vlax-3d-point 3 3 0)
width 40
height 40)
;; Create the line in paper space
(setq paperSpace (vla-get-PaperSpace doc))
(setq lineObj (vla-AddLine paperSpace startPoint endPoint))
;; Create the paper space viewport
(setq PViewPort (vla-AddPViewport paperSpace center width height))
;; Set the paper space viewport scale to custom
(vla-put-StandardScale PViewPort acVpCustomScale)
;; Change from model space to paper space
(vla-put-ActiveSpace doc acPaperSpace)
(vla-ZoomAll acadObj)
;; Read and display the existing paper space viewport scale setting
(alert (strcat "The scale of the new PViewport is: " (rtos (vla-get-CustomScale PViewPort) 2)))
;; Change the custom scale setting to 1:10 scale
(vla-put-CustomScale PViewPort 0.1)
;; Read and display the new paper space viewport scale setting
(alert (strcat "The scale of the new PViewport has been changed to: " (rtos (vla-get-CustomScale PViewPort) 2)))
GMT+8, 2026-10-28 00:01
