Contrast 属性 (ActiveX)
指定图像或参考底图的当前对比度值。 支持的平台:仅限 Windows 签名VBA: object.Contrast
属性值只读:不 类型:整数 有效范围为 0 到 100(含 0 到 100)。默认值为 50。 言论您可以调整图像亮度、对比度和淡入淡出以显示图像以及绘制的输出,而不会影响原始光栅图像或参考底图文件。调整亮度以使图像变暗或变亮。调整对比度,使质量较差的图像更易于阅读。调整淡入淡出使矢量在图像上更易于查看,并在绘制的输出中创建水印效果。 注意:无法调整双色调图像的亮度、对比度或淡入淡出。
例子VBA: Sub Example_Contrast()
' This example inserts a raster image and finds the current
' Contrast of the image. It then changes the Contrast
' of the image.
' This example uses the "2d Projected Polylines.jpg" found in the Sample
' directory. If you do not have the image, or if it is located
' in a different directory, insert a valid path and name for the
' imageName variable below.
Dim scalefactor As Double
Dim rotAngleInDegree As Double
Dim rotAngle As Double
Dim imageName As String
Dim raster As AcadRasterImage
imageName = "C:\AutoCAD\sample\2d Projected Polylines.jpg"
insertionPoint(0) = 2#: insertionPoint(1) = 2#: insertionPoint(2) = 0#
scalefactor = 1#
rotAngleInDegree = 0#
rotAngle = rotAngleInDegree * 3.141592 / 180#
On Error Resume Next
' Creates a raster image in model space
Set raster = ThisDrawing.modelSpace.AddRaster(imageName, insertionPoint, scalefactor, rotAngle)
If Err.Description = "File error" Then
MsgBox imageName & " could not be found."
Exit Sub
End If
' Find the current Contrast
ThisDrawing.Regen True
MsgBox "The Contrast is currently set to: " & raster.Contrast, vbInformation
' Change the Contrast to 5
raster.Contrast = 5
MsgBox "The Contrast is now set to: " & raster.Contrast, vbInformation
可视化 LISP: (vl-load-com)
(defun c:Example_Contrast()
;; This example inserts a raster image and finds the current
;; Contrast of the image. It then changes the Contrast
;; of the image.
;; This example uses the "2d Projected Polylines.jpg" found in the Sample
;; directory. If you do not have the image, or if it is located
;; in a different directory, insert a valid path and name for the
;; imageName variable below.
(setq insertionPoint (vlax-3d-point 2 2 0)
imageName ".\\Sample\\VBA\\2d Projected Polylines.jpg"
scalefactor 1
rotAngleInDegree 0
rotAngle (/ (* rotAngleInDegree 3.141592) 180))
(if (/= (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") nil)
(progn
;; Creates a raster image in model space
(setq raster (vla-AddRaster modelSpace (findfile ".\\Sample\\VBA\\2d Projected Polylines.jpg") insertionPoint scalefactor rotAngle))
(vla-ZoomExtents acadObj)
;; Find the current contrast
(vla-Regen doc :vlax-true)
(alert (strcat "The Contrast is currently set to: " (rtos (vla-get-Contrast raster) 2)))
;; Change the contrast to 5
(vla-put-Contrast raster 5)
(alert (strcat "The Contrast is now set to: " (rtos (vla-get-Contrast raster) 2)))
(alert (strcat imageName " could not be found."))
GMT+8, 2026-10-27 22:43
