ContourLinesPerSurface 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 767| 评论: 0|原作者: admin|来自: AutoCAD
指定对象上每个曲面的等值线(等值线)数。
object.ContourLinesPerSurface
类型:DatabasePreferences
此属性应用于的对象。
只读:不
类型:整数
有效范围为 0 到 2047。
此属性的初始值为 4。
ContourLinesPerSurface 设置为 4 的圆环
ContourLinesPerSurface 设置为 20 的圆环
注意:此属性的值存储在 ISOLINES 系统变量中。
Sub Example_ContourLinesPerSurface()
    ' ContourLinesPerSurface. It then changes the value, and finally
    Dim currContourLinesPerSurface As Integer
    Dim newContourLinesPerSurface As Integer
    ' Retrieve the current ContourLinesPerSurface value
    currContourLinesPerSurface = ThisDrawing.preferences.ContourLinesPerSurface
    MsgBox "The current value for ContourLinesPerSurface is " & currContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
    ' Change the value for ContourLinesPerSurface
    newContourLinesPerSurface = 2001
    ThisDrawing.preferences.ContourLinesPerSurface = newContourLinesPerSurface
    MsgBox "The new value for ContourLinesPerSurface is " & newContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
    ' Reset ContourLinesPerSurface to its original value
    ThisDrawing.preferences.ContourLinesPerSurface = currContourLinesPerSurface
    MsgBox "The ContourLinesPerSurface value is reset to " & currContourLinesPerSurface, vbInformation, "ContourLinesPerSurface Example"
(defun c:Example_ContourLinesPerSurface()
    ;; ContourLinesPerSurface. It then changes the value, and finally
    (setq preferences (vla-get-Preferences doc))
    ;; Retrieve the current ContourLinesPerSurface value
    (setq currContourLinesPerSurface (vla-get-ContourLinesPerSurface preferences))
    (alert (strcat "The current value for ContourLinesPerSurface is " (itoa currContourLinesPerSurface)))
    ;; Change the value for ContourLinesPerSurface
    (setq newContourLinesPerSurface 2001)
    (vla-put-ContourLinesPerSurface preferences newContourLinesPerSurface)
    (alert (strcat "The new value for ContourLinesPerSurface is " (itoa newContourLinesPerSurface)))
    ;; Reset ContourLinesPerSurface to its original value
    (vla-put-ContourLinesPerSurface preferences currContourLinesPerSurface)
    (alert (strcat "The ContourLinesPerSurface value is reset to " (itoa currContourLinesPerSurface)))
GMT+8, 2026-10-27 16:53
