ContinuousPlotLog 属性 (ActiveX)
指定是否保存连续的打印日志。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此特性等效于 AutoCAD 选项对话框设置“保存一个连续打印日志”和“每个打印保存一个日志”。 例子VBA: Sub Example_ContinuousPlotLog()
' This example changes the AutoCAD Options dialog box
' to specify one log per plot.
Dim MyPreference As AcadPreferencesOutput
Set MyPreference = AcadApplication.preferences.Output
MyPreference.ContinuousPlotLog = False
可视化 LISP: (vl-load-com)
(defun c:Example_ContinuousPlotLog()
;; This example changes the AutoCAD Options dialog box
;; to specify one log per plot.
(setq MyPreference (vla-get-Output preferences))
(vla-put-ContinuousPlotLog MyPreference :vlax-false)
GMT+8, 2026-10-28 19:40
