ConfigName 属性 (ActiveX)
指定绘图仪配置名称。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 布局或打印配置要使用的 PC3 文件或打印设备的名称。 言论此属性不采用完全限定的路径,而只采用配置文件的文件名。使用该属性指定打印机配置文件的路径。PrinterConfigPath 在尝试更改属性之前,请使用该方法。RefreshPlotDeviceInfoConfigName 不要为属性赋值“None”。尝试这样做会导致意外行为。ConfigName 例子VBA: Sub Example_ConfigName()
' This example will add a new plot configuration to the current drawing.
' It will then list the plotter configuration file name for each Layout
' in the current drawing, change the configuration for Layout1 to "DWF Classic.pc3"
' and re-display the configuration information for the drawing.
' * Note: File names may differ on your system, so be prepared to change
' the configuration file name used in the example to a file that exists
' on your system.
Dim Layouts As AcadLayouts, Layout As ACADLayout
Dim msg As String
Dim ACADPref As AcadPreferencesFiles
Dim originalValue As Variant
' Get the files preferences object
Set ACADPref = ThisDrawing.Application.preferences.Files
originalValue = ACADPref.PrinterConfigPath
' Get layouts collection from document object
Set Layouts = ThisDrawing.Layouts
' Display current plotter configuration information
GoSub DISPLAY_CONFIG
' Change plotter configuration file for "Layout1"
Layouts("Layout1").ConfigName = "DWF6 ePlot.pc3"
' Display new plotter configuration information
Exit Sub
DISPLAY_CONFIG:
msg = vbCrLf & vbCrLf ' Start with a space
' Format and display current directory for configuration files
msg = msg & vbTab & "Directories that will be scanned for the plotter configuration files are: " _
& vbCrLf & vbTab & vbTab & originalValue & vbCrLf & vbCrLf
' Get the plotter configuration name of every layout in this drawing
For Each Layout In Layouts
' Format for display
msg = msg & vbTab & Layout.name & " is using configuration: " & Layout.ConfigName & vbCrLf
Next
' Display paper units information
MsgBox "The plotter configuration information used in the current drawing is listed below." & msg
Return
可视化 LISP: (vl-load-com)
(defun c:Example_ConfigName()
;; This example will add a new plot configuration to the current drawing.
;; It will then list the plotter configuration file name for each Layout
;; in the current drawing, change the configuration for Layout1 to "DWF Classic.pc3"
;; and re-display the configuration information for the drawing.
;; * Note: File names may differ on your system, so be prepared to change
;; the configuration file name used in the example to a file that exists
;; on your system.
;; Get the files preferences object
(setq ACADPref (vla-get-Files (vla-get-Preferences acadObj)))
(setq originalValue (vla-get-PrinterConfigPath ACADPref))
;; Get layouts collection from document object
(setq Layouts (vla-get-Layouts doc))
;; Format and display current directory for configuration files
(setq msg "")
(setq msg (strcat msg "Directories that will be scanned for the plotter configuration files are: \n"
originalValue "\n"))
;; Get the plotter configuration name of every layout in this drawing
(vlax-for Layout Layouts
(setq msg (strcat msg "\n" (vla-get-Name Layout) " is using configuration: " (vla-get-ConfigName Layout)))
;; Display paper units information
(alert (strcat "The plotter configuration information used in the current drawing is listed below.\n\n" msg))
;; Change plotter configuration file for "Layout1"
(vla-put-ConfigName (vla-Item Layouts "Layout1") "DWF6 ePlot.pc3")
;; Display new plotter configuration information
(setq msg "")
GMT+8, 2026-10-26 19:07
