ConfigFile 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 607| 评论: 0|原作者: admin|来自: AutoCAD
获取用于存储硬件设备驱动程序信息的配置文件的位置。
object.ConfigFile
类型:PreferencesFiles
此属性应用于的对象。
只读:是的
类型:字符串
此值是只读的,只能使用命令行开关进行更改。有关命令行开关的详细信息,请参见 AutoCAD Online 帮助。/c
Sub Example_ConfigFile()
    ' This example returns the current setting of ConfigFile.
    Dim currConfigFile As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current ConfigFile value
    currConfigFile = preferences.Files.ConfigFile
    If currConfigFile = "" Then
        MsgBox "ConfigFile is not currently set.", vbInformation, "ConfigFile Example"
    Else
        MsgBox "The current value for ConfigFile is " & currConfigFile, vbInformation, "ConfigFile Example"
    End If
(defun c:Example_ConfigFile()
    ;; This example returns the current setting of ConfigFile.
    ;; Retrieve the current ConfigFile value
    (setq currConfigFile (vla-get-ConfigFile (vla-get-Files preferences)))
    (if (= currConfigFile "")
        (alert "ConfigFile is not currently set.")
        (alert (strcat "The current value for ConfigFile is " currConfigFile))
GMT+8, 2026-10-28 09:49
