Color 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 827| 评论: 0|原作者: admin|来自: AutoCAD
Color 属性 (ActiveX)
指定对象或图层的颜色。
object.Color
类型:所有绘图对象、组、图层、MLeaderLeader、SubDMeshEdge、SubDMeshFace、SubDMeshVertex、SubEntity、SubEntSolidEdge、SubEntSolidFace、SubEntSolidNode、SubEntSolidVertex
此属性应用于的对象。
只读:否(只写对象除外)Group
类型:枚举acColor
默认颜色名称为 。使用介于 0 到 256 之间的颜色索引号,或此处列出的常量之一:acByLayer
  • acByBlock
  • acByLayer(对对象无效)Layer
  • acRed
  • acYellow
  • acGreen
  • acCyan
  • acBlue
  • acMagenta
  • acWhite
对于大多数图形对象,此属性已过时,将在将来的版本中相应地删除。使用此属性时,可以设置颜色并将其读取为介于 0 到 256 之间的数字索引值。为标准七种颜色以及 BYBLOCK 和 BYLAYER 名称提供了常量。
如果使用 ,AutoCAD 将以默认颜色(白色或黑色,具体取决于您的配置)绘制新对象,直到它们被分组到块中。在图形中插入块时,块中的对象将继承颜色属性的当前设置。acByBlock
如果使用 ,则新对象将采用绘制它们的图层的颜色。该值对对象无效。acByLayeracByLayerLayer
Sub Example_Color()
    ' This example creates a polyline and colors it red.
    ' It then displays the current color setting for the polyline.
    Dim plineObj As AcadPolyline
    Dim currentcolor As Variant
    ' Create Polyline
    Dim points(8) As Double
    points(0) = 3: points(1) = 7: points(2) = 0
    points(3) = 9: points(4) = 2: points(5) = 0
    points(6) = 3: points(7) = 5: points(8) = 0
    Set plineObj = ThisDrawing.ModelSpace.AddPolyline(points)
    ' First set the color of the object to Red
    plineObj.Color = acRed
    ThisDrawing.Regen (True)
    ' Now retrieve and display the Color property
    currentcolor = plineObj.Color
    ' Translate the color from a number into text
    If currentcolor = 256 Then
        currentcolor = "By Layer"
    Else
        currentcolor = Choose(currentcolor + 1, "By Block", "Red", "Yellow", "Green", "Cyan", "Blue", "Magenta", "White")
    End If
    ' Display
    MsgBox "The Polyline color is: " & currentcolor, vbInformation, "Color Example"
(defun c:Example_Color()
    ;; This example creates a polyline and colors it red.
    ;; It then displays the current color setting for the polyline.
    ;; Create Polyline
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill points '(3 7 0
				  9 2 0
				  3 5 0
    (setq plineObj (vla-AddPolyline modelSpace points))
    ;; First set the color of the object to Red
    (vla-put-Color plineObj acRed)
    (vla-Regen doc :vlax-true)
    ;; Now retrieve and display the Color property
    (setq currentcolor (vla-get-Color plineObj))
    ;; Translate the color from a number into text
    (if (= currentcolor 256)
        (setq currentcolor "ByLayer")
        (setq currentcolor (cond
            ((= currentcolor 257) "ByBlock")
            ((= currentcolor 1) "Red")
            ((= currentcolor 2) "Yellow")
            ((= currentcolor 3) "Green")
            ((= currentcolor 4) "Cyan")
            ((= currentcolor 5) "Blue")
            ((= currentcolor 6) "Magenta")
            ((= currentcolor 7) "White/Black")
            ("Other")
    ;; Display
    (alert (strcat "The Polyline color is: " currentcolor))
GMT+8, 2026-10-26 19:52
