Clipped 属性 (ActiveX)
确定视口是否已被剪裁。 支持的平台:仅限 Windows 属性值只读:是的 类型:布尔
言论没有其他评论。 例子VBA: Sub Example_Clipped()
' This example scans the current drawing paper space Viewports
' and displays whether or not any of them are clipped.
Dim pviewportObj As Object
Dim msg As String, ClippedState As String
' Make sure this drawing contains paper space viewports before continuing
If ThisDrawing.PaperSpace.Count = 0 Then
MsgBox "There are no paper space viewports in the current drawing."
Exit Sub
End If
' Go through each PViewport object in the drawing paper space
' and determine whether the paper space viewport is clipped or not
For Each pviewportObj In ThisDrawing.PaperSpace
' Determine if this is a paper space viewport
If pviewportObj.ObjectName = "AcDbViewport" Then
' Determine if this paper space viewport is clipped
ClippedState = IIf(pviewportObj.Clipped, " is clipped", " is not clipped")
msg = msg & "PViewport ID " & pviewportObj.ObjectID & ClippedState & vbCrLf
End If
Next
' Display clipped state of paper space Viewports
MsgBox msg
可视化 LISP: (vl-load-com)
(defun c:Example_Clipped()
;; This example scans the current drawing paper space Viewports
;; and displays whether or not any of them are clipped.
;; Make sure this drawing contains paper space viewports before continuing
(if (= (vla-get-Count (vla-get-PaperSpace doc)) 0)
(alert "There are no paper space viewports in the current drawing.")
(progn
;; Go through each PViewport object in the drawing paper space
;; and determine whether the paper space viewport is clipped or not
(setq msg "")
(vlax-for pviewportObj (vla-get-PaperSpace doc)
;; Determine if this is a paper space viewport
(if (= (vla-get-ObjectName pviewportObj) "AcDbViewport")
(progn
;; Determine if this paper space viewport is clipped
(setq ClippedState (if (= (vla-get-Clipped pviewportObj) :vlax-true) " is clipped" " is not clipped"))
(setq msg (strcat msg "PViewport ID " (itoa (vla-get-ObjectID pviewportObj)) ClippedState "\n"))
;; Display clipped state of paper space Viewports
(alert msg)
GMT+8, 2026-10-28 02:42
