BookName 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 757| 评论: 0|原作者: admin|来自: AutoCAD
指定颜色的书籍名称(如果有)。
object.BookName
类型:AcCmColor
此属性应用于的对象。
只读:是的
类型:字符串
颜色来源的图画册的名称。
Sub Example_BookName()
    'This example draws a circle and
    'returns the color name and color book name of the color.
    Dim col As AcadAcCmColor
    Set col = AcadApplication.GetInterfaceObject("AutoCAD.AcCmColor." & Left(AcadApplication.Version, 2))
    col.SetRGB 125, 175, 235
    col.SetNames "MyColor", "MyColorBook"
    Dim cir As AcadCircle
    Dim pt(0 To 2) As Double
    Set cir = ThisDrawing.ModelSpace.AddCircle(pt, 2)
    cir.TrueColor = col
    ZoomAll
    Dim retCol As AcadAcCmColor
    Set retCol = cir.TrueColor
    MsgBox "BookName=" & col.BookName & vbLf & _
           "ColorName=" & col.ColorName
(defun c:Example_BookName()
    ;; This example draws a circle and
    ;; returns the color name and color book name of the color.
    (setq col (vlax-create-object (strcat "AutoCAD.AcCmColor." (substr (getvar "ACADVER") 1 2))))
    (vla-SetRGB col 125 175 235)
    (vla-SetNames col "MyColor" "MyColorBook")
    (setq pt (vlax-3d-point 0 0 0))
    (setq cir (vla-AddCircle modelSpace pt 2))
    (vla-put-TrueColor cir col)
    (vla-ZoomAll acadObj)
    (setq retCol (vla-get-TrueColor cir))
    (alert (strcat "BookName=" (vla-get-BookName col)
                   "\nColorName=" (vla-get-ColorName col)
    (vlax-release-object col)
GMT+8, 2026-10-27 13:30
