BeepOnError 属性 (ActiveX)
指定 AutoCAD 在检测到无效条目时是否应发出警报蜂鸣音。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 。False 例子VBA: Sub Example_BeepOnError()
' BeepOnError. It then changes the value, and finally
Dim currBeepOnError As Boolean
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current BeepOnError value
currBeepOnError = preferences.System.BeepOnError
MsgBox "The current value for BeepOnError is " & preferences.System.BeepOnError, vbInformation, "BeepOnError Example"
' Change the value for BeepOnError
preferences.System.BeepOnError = Not (currBeepOnError)
MsgBox "The new value for BeepOnError is " & preferences.System.BeepOnError, vbInformation, "BeepOnError Example"
' Reset BeepOnError to its original value
preferences.System.BeepOnError = currBeepOnError
MsgBox "The BeepOnError value is reset to " & preferences.System.BeepOnError, vbInformation, "BeepOnError Example"
可视化 LISP: (vl-load-com)
(defun c:Example_BeepOnError()
;; BeepOnError. It then changes the value, and finally
;; Retrieve the current BeepOnError value
(setq currBeepOnError (vla-get-BeepOnError (vla-get-System preferences)))
(alert (strcat "The current value for BeepOnError is " (if (= currBeepOnError :vlax-true) "True" "False")))
;; Change the value for BeepOnError
(vla-put-BeepOnError (vla-get-System preferences) (if (= currBeepOnError :vlax-true) :vlax-false :vlax-true))
(setq newBeepOnError (vla-get-BeepOnError (vla-get-System preferences)))
(alert (strcat "The new value for BeepOnError is " (if (= newBeepOnError :vlax-true) "True" "False")))
;; Reset BeepOnError to its original value
(vla-put-BeepOnError (vla-get-System preferences) currBeepOnError)
(alert (strcat "The BeepOnError value is reset to " (if (= currBeepOnError :vlax-true) "True" "False")))
GMT+8, 2026-10-27 18:36
