BackgroundFill 属性 (ActiveX)
指定多行文本是否具有背景填充。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论MText:此属性中包含的值是“属性”选项板中的“背景掩码”属性。 例子VBA: Sub Example_BackgroundFill()
' This example creates a circle and an MText object, and masks part of the
' circle with the MText object
'Draw a circle
Dim circleObj As AcadCircle
Dim CircleReference(0 To 2) As Double
Dim radius As Double
CircleReference(0) = 0
CircleReference(1) = 0
CircleReference(2) = 0
radius = 5
Set circleObj = ThisDrawing.ModelSpace.AddCircle(CircleReference, radius)
ZoomAll
MsgBox "A circle has been drawn."
'Create an MText object with the BackgroundFill property set to True
Dim MTextObj As AcadMText
Dim width As Double
Dim text As String
width = 10
text = "This is the text for the MText object"
Set MTextObj = ThisDrawing.ModelSpace.AddMText(CircleReference, width, text)
MTextObj.BackgroundFill = True
ZoomAll
可视化 LISP: (vl-load-com)
(defun c:Example_BackgroundFill()
;; This example creates a circle and an MText object, and masks part of the
;; circle with the MText object
;; Draw a circle
(setq CircleReference (vlax-3d-point 0 0 0)
radius 0.5)
(setq circleObj (vla-AddCircle modelSpace CircleReference radius))
(vla-ZoomAll acadObj)
(alert "A circle has been drawn.")
;; Create an MText object with the BackgroundFill property set to True
(setq width 5
text "This is the text for the MText object")
(setq MTextObj (vla-AddMText modelSpace CircleReference width text))
(vla-put-AttachmentPoint MTextObj 5)
(vla-put-InsertionPoint MTextObj CircleReference)
(vla-put-BackgroundFill MTextObj :vlax-true)
GMT+8, 2026-10-28 00:07
