AutoTrackingVecColor 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 1031| 评论: 0|原作者: admin|来自: AutoCAD
指定自动跟踪矢量的颜色。
object.AutoTrackingVecColor
类型:首选项起草
此属性应用于的对象。
只读:不
类型:OLE_COLOR(常量)
  • vbBlack
  • vbRed
  • vbYellow
  • vbGreen
  • vbCyan
  • vbBlue
  • vbMagenta
  • vbWhite
此属性的默认颜色为 。vbWhite
Sub Example_AutoTrackingVecColor()
    ' This example reads and modifies the preference value that controls
    ' the color of the AutoTrack vector. When finished, this example
    ' resets the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDisplay
    ' Get the display preferences object
    Set ACADPref = ThisDrawing.Application.preferences.DISPLAY
    originalValue = ACADPref.AutoTrackingVecColor
    MsgBox "The AutoTrackingVecColor preference is: " & originalValue
    ' Modify the AutoTrackingVecColor preference by making it red
    ACADPref.AutoTrackingVecColor = vbRed
    newValue = ACADPref.AutoTrackingVecColor
    MsgBox "The AutoTrackingVecColor preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AutoTrackingVecColor = originalValue
    MsgBox "The AutoTrackingVecColor preference was reset back to: " & originalValue
(defun c:Example_AutoTrackingVecColor()
    ;; This example reads and modifies the preference value that controls
    ;; the color of the AutoTrack vector. When finished, this example
    ;; resets the preference value back to its original value.
    ;; Get the Display preferences object
    (setq ACADPref (vla-get-Display preferences))
    (setq originalValue (vlax-variant-change-type (vla-get-AutoTrackingVecColor ACADPref) vlax-vbLong))
    (alert (strcat "The AutoTrackingVecColor preference is: " (itoa (vlax-variant-value originalValue))))
    ;; Modify the AutoTrackingVecColor preference by making it red
    (vla-put-AutoTrackingVecColor ACADPref (vlax-make-variant acRed 19))
    (setq newValue (vlax-variant-change-type (vla-get-AutoTrackingVecColor ACADPref) vlax-vbLong))
    (alert (strcat "The AutoTrackingVecColor preference has been set to: " (itoa (vlax-variant-value newValue))))
    ;;         this preference in effect
    (vla-put-AutoTrackingVecColor ACADPref (vlax-variant-change-type originalValue 19))
    (alert (strcat "The AutoTrackingVecColor preference was reset back to: " (itoa (vlax-variant-value originalValue))))
GMT+8, 2026-10-27 13:31
