AutoSnapMarkerSize 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 790| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoSnap 标记的大小。
object.AutoSnapMarkerSize
类型:首选项起草
此属性应用于的对象。
只读:
类型:
一个介于 1 到 20 之间的值,表示 AutoSnap 标记的大小(以像素为单位)。
Sub Example_AutoSnapMarkerSize()
    ' This example reads and modifies the preference value that controls
    ' the size of the AutoSnap marker. When finished, this example resets
    ' the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDrafting
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Drafting
    originalValue = ACADPref.AutoSnapMarkerSize
    MsgBox "The AutoSnapMarkerSize preference is: " & originalValue
    ' Modify the AutoSnapMarkerSize preference by setting it to 10
    ACADPref.AutoSnapMarkerSize = 10
    newValue = ACADPref.AutoSnapMarkerSize
    MsgBox "The AutoSnapMarkerSize preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AutoSnapMarkerSize = originalValue
    MsgBox "The AutoSnapMarkerSize preference was reset back to: " & originalValue
(defun c:Example_AutoSnapMarkerSize()
    ;; This example reads and modifies the preference value that controls
    ;; the size of the AutoSnap marker. When finished, this example resets
    ;; the preference value back to its original value.
    ;; Get the drafting preferences object
    (setq ACADPref (vla-get-Drafting preferences))
    (setq originalValue (vla-get-AutoSnapMarkerSize ACADPref))
    (alert (strcat "The AutoSnapMarkerSize preference is: " (itoa originalValue)))
    ;; Modify the AutoSnapMarkerSize preference by setting it to 10
    (vla-put-AutoSnapMarkerSize ACADPref 10)
    (setq newValue (vla-get-AutoSnapMarkerSize ACADPref))
    (alert (strcat "The AutoSnapMarkerSize preference has been set to: " (itoa newValue)))
    ;;         this preference in effect
    (vla-put-AutoSnapMarkerSize ACADPref originalValue)
    (alert (strcat "The AutoSnapMarkerSize preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-9-13 05:00
