AutoSnapMarker 属性 (ActiveX)
切换 AutoSnap 标记。 支持的平台:仅限 Windows 属性值只读:不 类型:布尔
言论此属性的初始值为 True。 注意:此属性的值存储在 AUTOSNAP 系统变量中。
例子VBA: Sub Example_AutoSnapMarker()
' This example reads and modifies the preference value that controls
' the AutoSnap marker. When finished, this example resets the
' preference value back to its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Drafting
originalValue = ACADPref.AutoSnapMarker
MsgBox "The AutoSnapMarker preference is set to: " & originalValue
' Modify the AutoSnapMarker preference by toggling the value
ACADPref.AutoSnapMarker = Not (originalValue)
newValue = ACADPref.AutoSnapMarker
MsgBox "The AutoSnapMarker preference has been set to: " & newValue
' this preference in effect
ACADPref.AutoSnapMarker = originalValue
MsgBox "The AutoSnapMarker preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_AutoSnapMarker()
;; This example reads and modifies the preference value that controls
;; the AutoSnap marker. When finished, this example resets the
;; preference value back to its original value.
;; Get the drafting preferences object
(setq ACADPref (vla-get-Drafting preferences))
(setq originalValue (vla-get-AutoSnapMarker ACADPref))
(alert (strcat "The AutoSnapMarker preference is set to: " (if (= originalValue :vlax-true) "True" "False")))
;; Modify the AutoSnapMarker preference by toggling the value
(vla-put-AutoSnapMarker ACADPref (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-AutoSnapMarker ACADPref))
(alert (strcat "The AutoSnapMarker preference has been set to: " (if (= newValue :vlax-true) "True" "False")))
;; this preference in effect
(vla-put-AutoSnapMarker ACADPref originalValue)
(alert (strcat "The AutoSnapMarker preference was reset back to: " (if (= originalValue :vlax-true) "True" "False")))
GMT+8, 2026-10-26 19:51
