AutoSnapApertureSize 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 848| 评论: 0|原作者: admin|来自: AutoCAD
指定 AutoSnap 光圈的大小。
object.AutoSnapApertureSize
类型:首选项起草
此属性应用于的对象。
只读:
类型:
AutoSnap 光圈的大小(以像素为单位)。
此属性的初始值为 10。
当您捕捉到对象时,AutoSnap 光圈显示在十字准线的中心。仅当启用了 AutoSnap 标记、磁贴或工具提示时,此选项才可用。
注意:此属性的值存储在 APERTURE 系统变量中。
Sub Example_AutoSnapApertureSize()
    ' This example reads and modifies the preference value that controls
    ' the size of the AutoSnap aperture. When finished, this example resets
    ' the preference value back to its original value.
    Dim ACADPref As AcadPreferencesDrafting
    ' Get the drafting preferences object
    Set ACADPref = ThisDrawing.Application.preferences.Drafting
    originalValue = ACADPref.AutoSnapApertureSize
    MsgBox "The AutoSnapApertureSize preference is: " & originalValue
    ' Modify the AutoSnapApertureSize preference by setting it to 25
    ACADPref.AutoSnapApertureSize = 25
    newValue = ACADPref.AutoSnapApertureSize
    MsgBox "The AutoSnapApertureSize preference has been set to: " & newValue
    '         this preference in effect
    ACADPref.AutoSnapApertureSize = originalValue
    MsgBox "The AutoSnapApertureSize preference was reset back to: " & originalValue
(defun c:Example_AutoSnapApertureSize()
    ;; This example reads and modifies the preference value that controls
    ;; the size of the AutoSnap aperture. When finished, this example resets
    ;; the preference value back to its original value.
    ;; Get the drafting preferences object
    (setq ACADPref (vla-get-Drafting preferences))
    (setq originalValue (vla-get-AutoSnapApertureSize ACADPref))
    (alert (strcat "The AutoSnapApertureSize preference is set to: " (itoa originalValue)))
    ;; Modify the AutoSnapApertureSize preference by setting it to 25
    (vla-put-AutoSnapApertureSize ACADPref 25)
    (setq newValue (vla-get-AutoSnapApertureSize ACADPref))
    (alert (strcat "The AutoSnapApertureSize preference has been set to: " (itoa newValue)))
    ;;         this preference in effect
    (vla-put-AutoSnapApertureSize ACADPref originalValue)
    (alert (strcat "The AutoSnapApertureSize preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-9-18 14:05
