AutoSaveInterval 属性 (ActiveX)
指定自动保存间隔(以分钟为单位)。 支持的平台:仅限 Windows 属性值只读:不 类型:整数 0 >= 自动保存间隔 <= 600 等于 0 的间隔将禁用自动保存。 大于 0 的间隔会自动以指定的间隔保存图形。 言论此属性的初始设置为 120。 对图形进行更改后,计时器将立即启动。每当保存图形时,它就会重置并重新启动。除非使用该属性指定了其他名称,否则当前图形将保存为 auto.sv$。AutoSavePath 注意:此属性也由 SAVETIME 系统变量控制。ISAVEBAK 系统变量(使用属性设置)可提高增量保存的速度,尤其是对于较大的图形。ISAVEPERCENT 系统变量(使用该属性设置)确定图形中允许的浪费空间量。CreateBackupIncrementalSavePercent
例子VBA: Sub Example_AutoSaveInterval()
' AutoSaveInterval. It then changes the value, and finally
Dim currAutoSaveInterval As Integer
Dim newAutoSaveInterval As Integer
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current AutoSaveInterval value
currAutoSaveInterval = preferences.OpenSave.AutoSaveInterval
MsgBox "The current value for AutoSaveInterval is " & currAutoSaveInterval, vbInformation, "AutoSaveInterval Example"
' Change the value for AutoSaveInterval
If currAutoSaveInterval = 0 Then
newAutoSaveInterval = 10
Else
newAutoSaveInterval = 0
End If
preferences.OpenSave.AutoSaveInterval = newAutoSaveInterval
MsgBox "The new value for AutoSaveInterval is " & newAutoSaveInterval, vbInformation, "AutoSaveInterval Example"
' Reset AutoSaveInterval to its original value
preferences.OpenSave.AutoSaveInterval = currAutoSaveInterval
MsgBox "The AutoSaveInterval value is reset to " & currAutoSaveInterval, vbInformation, "AutoSaveInterval Example"
可视化 LISP: (vl-load-com)
(defun c:Example_AutoSaveInterval()
;; AutoSaveInterval. It then changes the value, and finally
;; Retrieve the current AutoSaveInterval value
(setq currAutoSaveInterval (vla-get-AutoSaveInterval (vla-get-OpenSave preferences)))
(alert (strcat "The current value for AutoSaveInterval is " (itoa currAutoSaveInterval)))
;; Change the value for AutoSaveInterval
(if (= currAutoSaveInterval 0)
(setq newAutoSaveInterval 10)
(setq newAutoSaveInterval 0)
(vla-put-AutoSaveInterval (vla-get-OpenSave preferences) newAutoSaveInterval)
(alert (strcat "The new value for AutoSaveInterval is " (itoa newAutoSaveInterval)))
;; Reset AutoSaveInterval to its original value
(vla-put-AutoSaveInterval (vla-get-OpenSave preferences) currAutoSaveInterval)
(alert (strcat "The AutoSaveInterval value is reset to " (itoa currAutoSaveInterval)))
GMT+8, 2026-10-27 13:31
