Arrowhead1Type 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 744| 评论: 0|原作者: admin|来自: AutoCAD
指定尺寸线第一端的箭头类型。
object.Arrowhead1Type
类型:Dim3PointAngular、DimAligned、DimAngular、DimArcLength、DimDiametric、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimArrowheadType
  • acArrowDefault
  • acArrowDot
  • acArrowDotSmall
  • acArrowDotBlank
  • acArrowOrigin
  • acArrowOrigin2
  • acArrowOpen
  • acArrowOpen90
  • acArrowOpen30
  • acArrowClosed
  • acArrowSmall
  • acArrowNone
  • acArrowOblique
  • acArrowBoxFilled
  • acArrowBoxBlank
  • acArrowClosedBlank
  • acArrowDatumFilled
  • acArrowDatumBlank
  • acArrowIntegral
  • acArrowArchTick
  • acArrowUserDefined只读
此属性的初始值为 。acArrowDefault
使用该属性指定要用作自定义箭头的块时,此属性将设置为 。Arrowhead1BlockacArrowUserDefined
注意:此属性将覆盖给定维度的 DIMBLK1 系统变量的值。
Sub Example_ArrowHead1Type()
    ' This example creates a Dim3PointAngular object in model space
    ' and then alters the visible appearance (shape) of its arrowheads
    ' using the ArrowHead1Type and ArrowHead2Type properties
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Read and display current arrowhead type
    MsgBox "The arrowhead type for the first arrow of this object is: " & DimPointAngularObj.Arrowhead1Type & vbCrLf & _
           "The arrowhead type for the second arrow of this object is: " & DimPointAngularObj.Arrowhead2Type
    ' Alter the arrowhead type property for both arrows of this object
    DimPointAngularObj.Arrowhead1Type = acArrowBoxBlank
    DimPointAngularObj.Arrowhead2Type = acArrowBoxBlank
    MsgBox "The arrowhead type for the first arrow of this object is now set to: " & DimPointAngularObj.Arrowhead1Type & vbCrLf & _
           "The arrowhead type for the second arrow of this object is now set to: " & DimPointAngularObj.Arrowhead2Type
(defun c:Example_ArrowHead1Type()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and then alters the visible appearance (shape) of its arrowheads
    ;; using the ArrowHead1Type and ArrowHead2Type properties
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Read and display current arrowhead type
    (alert (strcat "The arrowhead type for the first arrow of this object is: " (itoa (vla-get-Arrowhead1Type DimPointAngularObj))
                   "\nThe arrowhead type for the second arrow of this object is: " (itoa (vla-get-Arrowhead2Type DimPointAngularObj))))
    ;; Alter the arrowhead type property for both arrows of this object
    (vla-put-Arrowhead1Type DimPointAngularObj acArrowBoxBlank)
    (vla-put-Arrowhead2Type DimPointAngularObj acArrowBoxBlank)
    (alert (strcat "The arrowhead type for the first arrow of this object is now set to: " (itoa (vla-get-Arrowhead1Type DimPointAngularObj))
                   "\nThe arrowhead type for the second arrow of this object is now set to: " (itoa (vla-get-Arrowhead2Type DimPointAngularObj))))
GMT+8, 2026-10-28 13:20
