Application 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 562| 评论: 0|原作者: admin|来自: AutoCAD
获取 Application 对象。
object.Application
类型:所有对象
此属性应用于的对象。
只读:是的
类型: 应用
作为对象所有者的对象。Application
该对象表示应用程序的框架控件和路径设置,并提供在对象层次结构中向下导航的方法。Application
发行信息
释放:AutoCAD 2000 到 AutoCAD 2017
Sub Example_Application()
    ' This example creates a line and then uses the
    ' Application property of the line to return the
    ' application name.
    Dim lineObj As AcadLine
    Dim myApp As AcadApplication
    ' Create a new line reference
    startPoint(0) = 0: startPoint(1) = 0: startPoint(2) = 0
    endPoint(0) = 2: endPoint(1) = 2: endPoint(2) = 0
    lineObj.Update
    ' Return the application for the object
    Set myApp = lineObj.Application
    ' Display the name of the application
    MsgBox "The application name is: " & myApp.name, vbInformation, "Application Example"
(defun c:Example_Application()
    ;; This example creates a line and then uses the
    ;; Application property of the line to return the
    ;; application name.
    ;; Create a new line reference
    (setq startPoint (vlax-3d-point 0 0 0)
          endPoint (vlax-3d-point 2 2 0))
    (vla-Update lineObj)
    ;; Return the application for the object
    (setq myApp (vla-get-Application lineObj))
    ;; Display the name of the application
    (alert (strcat "The application name is: " (vla-get-Name myApp)))
GMT+8, 2026-10-27 19:24
