Annotation 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 817| 评论: 0|原作者: admin|来自: AutoCAD
指定引线的批注对象。
object.Annotation
类型:领导者
此属性应用于的对象。
只读:不
类型:BlockReference、MText、Tolerance
引线的批注对象。引线注释可以是公差对象、多行文本对象或块参照。
并非所有引线都有批注对象。如果引线没有注释,则此属性将返回(逻辑)。若要测试 VB 或 VBA 中的逻辑值,请使用关键字。NothingFalseFalseNothing
Sub Example_Annotation()
    ' This example creates a leader in model space with an associated
    ' annotation and then checks for the existence of an
    ' Annotation object for the new Leader
    Dim leaderObj As AcadLeader, MTextObj As AcadMText
    Dim points(0 To 8) As Double, insertionPoint(0 To 2) As Double, width As Double
    Dim leaderType As Integer
    Dim annotationObject As Object
    Dim textString As String, msg As String
    ' Define the new MText object
    textString = "Hello, World."
    insertionPoint(0) = 5: insertionPoint(1) = 5: insertionPoint(2) = 0
    width = 2
    ' Create the MText object in model space
    Set MTextObj = ThisDrawing.ModelSpace.AddMText(insertionPoint, width, textString)
    ' Data for Leader
    points(0) = 0: points(1) = 0: points(2) = 0
    points(3) = 4: points(4) = 4: points(5) = 0
    points(6) = 4: points(7) = 5: points(8) = 0
    leaderType = acLineWithArrow
    ' Create the Leader object in model space and Associate new MText object
    ' with new Leader by making the MText object the annotation for the Leader
    Set annotationObject = MTextObj
    Set leaderObj = ThisDrawing.ModelSpace.AddLeader(points, annotationObject, leaderType)
    ' Display whether or not this particular Leader has an associated Annotation
    msg = IIf(leaderObj.Annotation Is Nothing, "does not have", "has")
    MsgBox "The new Leader object " & msg & " an associated Annotation object."
(defun c:Example_Annotation()
    ;; This example creates a leader in model space with an associated
    ;; annotation and then checks for the existence of an
    ;; Annotation object for the new Leader
    ;; Define the new MText object
    (setq insertionPoint (vlax-3d-point 5 5 0)
          textString "Hello, World."
          width 2)
    ;; Create the MText object in model space
    (setq MTextObj (vla-AddMText modelSpace insertionPoint width textString))
    ;; Data for Leader
    (setq points (vlax-make-safearray vlax-vbDouble '(0 . 8)))
    (vlax-safearray-fill points '(0 0 0
				  4 4 0
				  4 5 0
    (setq leaderType acLineWithArrow)
    ;; Create the Leader object in model space and Associate new MText object
    ;; with new Leader by making the MText object the annotation for the Leader
    (setq annotationObject MTextObj)
    (setq leaderObj (vla-AddLeader modelSpace points annotationObject leaderType))
    (vla-ZoomAll acadObj)
    (alert "The new Leader object has an associated Annotation object.")
GMT+8, 2026-10-29 00:06
