AngleFormat 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 799| 评论: 0|原作者: admin|来自: AutoCAD
指定角度尺寸的单位格式。
object.AngleFormat
类型:Dim3PointAngular、DimAngular
此属性应用于的对象。
只读:不
类型:枚举acAngleUnits
  • acDegrees
  • acDegreeMinuteSeconds
  • acGrads
  • acRadians
此属性的初始值为 。acDegrees
注意:此属性将覆盖给定尺寸的 DIMAUNIT 系统变量的值。
Sub Example_AngleFormat()
    ' This example creates a Dim3PointAngular object in model space
    ' and sets its Angle Format to some common values
    Dim DimPointAngularObj As AcadDim3PointAngular
    Dim AngleVertex(0 To 2) As Double
    Dim FirstPoint(0 To 2) As Double, SecondPoint(0 To 2) As Double
    Dim TextPoint(0 To 2) As Double
    ' Define the new Dim3PointAngular object
    AngleVertex(0) = 0: AngleVertex(1) = 0: AngleVertex(2) = 0
    FirstPoint(0) = 2: FirstPoint(1) = 2: FirstPoint(2) = 0
    SecondPoint(0) = 1: SecondPoint(1) = 4: SecondPoint(2) = 0
    TextPoint(0) = 6: TextPoint(1) = 6: TextPoint(2) = 0
    ' Create the new Dim3PointAngular object in model space
    Set DimPointAngularObj = ThisDrawing.ModelSpace.AddDim3PointAngular(AngleVertex, FirstPoint, SecondPoint, TextPoint)
    ' Cycle through some common angle formats
    DimPointAngularObj.AngleFormat = acDegreeMinuteSeconds
    MsgBox "The angle format of the new Dim3PointAngular object is now set to degree/minute/second"
    DimPointAngularObj.AngleFormat = acGrads
    MsgBox "The angle format of the new Dim3PointAngular object is now set to grads"
    DimPointAngularObj.AngleFormat = acRadians
    MsgBox "The angle format of the new Dim3PointAngular object is now set to radians"
(defun c:Example_AngleFormat()
    ;; This example creates a Dim3PointAngular object in model space
    ;; and sets its Angle Format to some common values
    ;; Define the new Dim3PointAngular object
    (setq AngleVertex (vlax-3d-point 0 0 0)
          FirstPoint (vlax-3d-point 2 2 0)
          SecondPoint (vlax-3d-point 1 4 0)
          TextPoint (vlax-3d-point 6 6 0))
    ;; Create the new Dim3PointAngular object in model space
    (setq DimPointAngularObj (vla-AddDim3PointAngular modelSpace AngleVertex FirstPoint SecondPoint TextPoint))
    (vla-ZoomAll acadObj)
    ;; Cycle through some common angle formats
    (vla-put-AngleFormat DimPointAngularObj acDegreeMinuteSeconds)
    (alert "The angle format of the new Dim3PointAngular object is now set to degree/minute/second.")
    (vla-put-AngleFormat DimPointAngularObj acGrads)
    (alert "The angle format of the new Dim3PointAngular object is now set to grads.")
    (vla-put-AngleFormat DimPointAngularObj acRadians)
    (alert "The angle format of the new Dim3PointAngular object is now set to radians.")
GMT+8, 2026-10-28 01:29
