AltUnitsPrecision 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 909| 评论: 0|原作者: admin|来自: AutoCAD
指定备用单位中的小数位数。
object.AltUnitsPrecision
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:枚举acDimPrecision
使用以下常量之一指定精度:
  • acDimPrecisionZero: 0.
  • acDimPrecisionOne: 0.0
  • acDimPrecisionTwo: 0.00
  • acDimPrecisionThree: 0.000
  • acDimPrecisionFour: 0.0000
  • acDimPrecisionFive: 0.00000
  • acDimPrecisionSix: 0.000000
  • acDimPrecisionSeven: 0.0000000
  • acDimPrecisionEight: 0.00000000
此属性的初始值为 。acDimPrecisionTwo
注意:此属性将覆盖给定维度的 DIMALTD 系统变量的值。
Sub Example_AltUnitsPrecision()
    ' uses AltUnitsPrecision to allow the user to change the
    ' precision of the alternate dimension
    Dim dimObj As AcadDimAligned
    Dim oldPrecision As String, newPrecision As String
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 5.12345678: point2(1) = 5: point2(2) = 0
    ' Enable alternate unit display
    dimObj.AltUnits = True
    ' Store old Precision value as default for input box
    oldPrecision = dimObj.AltUnitsPrecision
    ' Allow the user to change the precision for the alternate dimension
    newPrecision = InputBox("Enter a new precision for the alternate dimension.  The value must range from 0 to 8.", "Alternate Dimension Precision", oldPrecision)
    Select Case newPrecision
        Case 0: newPrecision = acDimPrecisionZero
        Case 1: newPrecision = acDimPrecisionOne
        Case 2: newPrecision = acDimPrecisionTwo
        Case 3: newPrecision = acDimPrecisionThree
        Case 4: newPrecision = acDimPrecisionFour
        Case 5: newPrecision = acDimPrecisionFive
        Case 6: newPrecision = acDimPrecisionSix
        Case 7: newPrecision = acDimPrecisionSeven
        Case 8: newPrecision = acDimPrecisionEight
        Case Else
            MsgBox "The alternate precision has not been changed."
            Exit Sub
    End Select
    dimObj.AltUnitsPrecision = newPrecision   ' Commit changes to precision
    ' Read back and display the alternate dimension precision
    newPrecision = dimObj.AltUnitsPrecision
    MsgBox "The alternate dimension precision has been set to " & newPrecision & " decimal places"
(defun c:Example_AltUnitsPrecision()
    ;; uses AltUnitsPrecision to allow the user to change the
    ;; precision of the alternate dimension
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 5.12345678 5 0)
    ;; Enable alternate unit display
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-ZoomAll acadObj)
    ;; Store old Precision value as default for input box
    (setq oldPrecision (vla-get-AltUnitsPrecision dimObj))
    ;; Allow the user to change the precision for the alternate dimension
    (if (= (setq newPrecision (getint "\nEnter a new precision for the alternate dimension (0-8): ")) nil) (setq newPrecision oldPrecision))
    (cond
      ((= newPrecision 0)(setq newPrecision acDimPrecisionZero))
      ((= newPrecision 1)(setq newPrecision acDimPrecisionOne))
      ((= newPrecision 2)(setq newPrecision acDimPrecisionTwo))
      ((= newPrecision 3)(setq newPrecision acDimPrecisionThree))
      ((= newPrecision 4)(setq newPrecision acDimPrecisionFour))
      ((= newPrecision 5)(setq newPrecision acDimPrecisionFive))
      ((= newPrecision 6)(setq newPrecision acDimPrecisionSix))
      ((= newPrecision 7)(setq newPrecision acDimPrecisionSeven))
      ((= newPrecision 8)(setq newPrecision acDimPrecisionEight))
      ((progn (alert "The alternate precision has not been changed.")(setq newPrecision oldPrecision)))
    (vla-put-AltUnitsPrecision dimObj newPrecision)   ;; Commit changes to precision
    ;; Read back and display the alternate dimension precision
    (setq newPrecision (vla-get-AltUnitsPrecision dimObj))
    (alert (strcat "The alternate dimension precision has been set to " (itoa newPrecision) " decimal places."))
GMT+8, 2026-10-27 14:26
