AltUnits 属性 (ActiveX)
启用以备用单位进行尺寸标注。 支持的平台:仅限 Windows 签名VBA: object.AltUnits
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性将覆盖给定维度的 DIMALT 系统变量的值。
例子VBA: Sub Example_AltUnits()
' uses AltUnits to toggle the alternate dimension units on and off
Dim dimObj As AcadDimAligned
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5: point2(1) = 5: point2(2) = 0
' Toggle alternate unit display
Toggle:
Select Case MsgBox("Press OK to toggle the display of alternate dimensions", vbOKCancel)
Case vbOK
' Toggle the alternate dimension display
dimObj.AltUnits = Not (dimObj.AltUnits)
Case vbCancel
Exit Sub
End Select
' Display status of alternate units display
If dimObj.AltUnits Then
MsgBox "Alternate units display is on."
Else
MsgBox "Alternate units display is off."
End If
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_AltUnits()
;; uses AltUnits to toggle the alternate dimension units on and off
;; Define the dimension
(setq point1 (vlax-3d-point 0 5 0)
point2 (vlax-3d-point 5 5 0)
(vla-ZoomAll acadObj)
;; Toggle alternate unit display
(setq originalValue (vla-get-AltUnits dimObj))
(alert "Toggling the display of alternate units.")
;; Toggle the display of trailing zeros for the alternate dimension tolerance value
(vla-put-AltUnits dimObj (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-AltUnits dimObj))
(alert "Toggling the display of alternate units to original value.")
(vla-put-AltUnits dimObj (if (= newValue :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-28 19:36
