AltToleranceSuppressZeroInches 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 813| 评论: 0|原作者: admin|来自: AutoCAD
指定在备用公差值中隐含零英寸测量值。
object.AltToleranceSuppressZeroInches
类型:DimAligned、DimArcLength、DimDiametric、DimOrdinate、DimRadial、DimRadialLarge、DimRotated
此属性应用于的对象。
只读:不
类型:布尔
  • True:禁止显示零英寸测量值。
  • False:请勿禁止显示零英寸测量值。
此属性的初始值为 。False
注意:此属性将覆盖给定维度的 DIMALTTZ 系统变量的值。
Sub Example_AltToleranceSuppressZeroInches()
   ' uses AltToleranceSuppressZeroInches to suppress or view the display of
   ' zero inches in the alternate dimension tolerance display
    Dim dimObj As AcadDimAligned
    ' Define the dimension
    point1(0) = 0: point1(1) = 5: point1(2) = 0
    point2(0) = 12: point2(1) = 5: point2(2) = 0
    ' Set up alternate unit tolerance display
    dimObj.AltUnits = True
    dimObj.ToleranceDisplay = acTolLimits
    ' Set the dimension display to a style that works with AltToleranceSuppressZeroInches
    dimObj.AltUnitsFormat = acDimLArchitectural
    dimObj.AltUnitsScale = 2    ' Set the alternate unit scale to be a multiple of 2
Toggle:
    Select Case MsgBox("Press OK to suppress or view the display of zero inches in the alternate dimension tolerance", vbOKCancel)
        Case vbOK
            ' Toggle the display of zero inches for the alternate dimension tolerance value
            dimObj.AltToleranceSuppressZeroInches = Not (dimObj.AltToleranceSuppressZeroInches)
        Case vbCancel
            Exit Sub
    End Select
    GoTo Toggle
(defun c:Example_AltToleranceSuppressZeroInches()
    ;; uses AltToleranceSuppressZeroInches to suppress or view the display of
    ;; zero inches in the alternate dimension tolerance display
    ;; Define the dimension
    (setq point1 (vlax-3d-point 0 5 0)
          point2 (vlax-3d-point 12 5 0)
    ; Create an aligned dimension object in model space
    ;; Set up alternate unit tolerance display
    (vla-put-AltUnits dimObj :vlax-true)
    (vla-put-ToleranceDisplay dimObj acTolLimits)
    ;; Set the dimension display to a style that works with AltToleranceSuppressZeroInches
    (vla-put-AltUnitsFormat dimObj acDimLArchitectural)
    (vla-put-AltUnitsScale dimObj 2)    ;; Set the alternate unit scale to be a multiple of 2
    (vla-ZoomAll acadObj)
    ;; Toggle the display of zero inches for the alternate dimension tolerance value
    (vla-put-AltToleranceSuppressZeroInches dimObj (if (= (vla-get-AltToleranceSuppressZeroInches dimObj) :vlax-true) :vlax-false :vlax-true))
    (alert "Suppression of zero inches in the alternate dimension tolerance toggled.")
    ;; Toggle the display of zero inches for the alternate dimension tolerance value back to previous state
    (alert "Suppression of zero inches in the alternate dimension tolerance toggled back.")
GMT+8, 2026-10-28 09:51
