AltToleranceSuppressZeroFeet 属性 (ActiveX)
指定在备用公差值中隐含零英尺测量值。 支持的平台:仅限 Windows 签名VBA: object.AltToleranceSuppressZeroFeet
属性值只读:不 类型:布尔
言论此属性的初始值为 。False 注意:此属性将覆盖给定维度的 DIMALTTZ 系统变量的值。
例子VBA: Sub Example_AltToleranceSuppressZeroFeet()
' uses AltToleranceSuppressZeroFeet to suppress or view the display of
' zero feet in the alternate dimension tolerance display
Dim dimObj As AcadDimAligned
' Define the dimension
point1(0) = 0: point1(1) = 5: point1(2) = 0
point2(0) = 5: point2(1) = 5: point2(2) = 0
' Set up alternate unit tolerance display
dimObj.AltUnits = True
dimObj.ToleranceDisplay = acTolLimits
' Set the dimension display to a style that works with AltToleranceSuppressZeroFeet
dimObj.AltUnitsFormat = acDimLArchitectural
dimObj.AltUnitsScale = 2 ' Set the alternate unit scale to be a multiple of 2
Toggle:
Select Case MsgBox("Press OK to suppress or view the display of zero feet in the alternate dimension tolerance", vbOKCancel)
Case vbOK
' Toggle the display of zero feet for the alternate dimension value
dimObj.AltToleranceSuppressZeroFeet = Not (dimObj.AltToleranceSuppressZeroFeet)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_AltToleranceSuppressZeroFeet()
;; uses AltToleranceSuppressZeroFeet to suppress or view the display of
;; zero feet in the alternate dimension tolerance display
;; Define the dimension
point2 (vlax-3d-point 6.01 5 0)
;; Set up alternate unit tolerance display
(vla-put-AltUnits dimObj :vlax-true)
(vla-put-ToleranceDisplay dimObj acTolLimits)
;; Set the dimension display to a style that works with AltToleranceSuppressZeroFeet
(vla-put-AltUnitsFormat dimObj acDimLArchitectural)
(vla-put-AltUnitsScale dimObj 2) ;; Set the alternate unit scale to be a multiple of 2
(vla-ZoomAll acadObj)
;; Toggle the display of zero feet for the alternate dimension value
(vla-put-AltToleranceSuppressZeroFeet dimObj (if (= (vla-get-AltToleranceSuppressZeroFeet dimObj) :vlax-true) :vlax-false :vlax-true))
(alert "Suppression of zero feet in the alternate dimension tolerance toggled.")
;; Toggle the display of zero feet for the alternate dimension value back to previous state
(alert "Suppression of zero feet in the alternate dimension tolerance toggled back.")
GMT+8, 2026-10-28 00:05
