AltSuppressTrailingZeros 属性 (ActiveX)
指定禁止在备用维度值中隐藏尾随零。 支持的平台:仅限 Windows 签名VBA: object.AltSuppressTrailingZeros
属性值只读:不 类型:布尔
言论此属性的初始值为 False。 注意:此属性将覆盖给定维度的 DIMALTZ 系统变量的值。
例子VBA: Sub Example_AltSuppressTrailingZeros()
' uses AltSuppressTrailingZeros to toggle the display of trailing zeros
' in the alternate dimension display
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 7: point2(1) = 5: point2(2) = 0
' Enable alternate unit display
dimObj.AltUnits = True
Toggle:
Select Case MsgBox("Press OK to toggle the display of trailing zeros in the alternate dimension", vbOKCancel)
Case vbOK
' Toggle the display of trailing zeros for the alternate dimension value
dimObj.AltSuppressTrailingZeros = Not (dimObj.AltSuppressTrailingZeros)
Case vbCancel
Exit Sub
End Select
GoTo Toggle
可视化 LISP: (vl-load-com)
(defun c:Example_AltSuppressTrailingZeros()
;; uses AltSuppressTrailingZeros to toggle the display of trailing zeros
;; in the alternate dimension display
;; Define the dimension
point2 (vlax-3d-point 7 5 0)
;; Enable alternate unit display
(vla-put-AltUnits dimObj :vlax-true)
;; Set up alternate unit tolerance display
(setq originalValue (vla-get-AltSuppressTrailingZeros dimObj))
(vla-put-AltSuppressTrailingZeros dimObj :vlax-true)
(vla-ZoomAll acadObj)
(alert "Toggling the display of trailing zeros in the alternate dimension.")
;; Toggle the display of trailing zeros for the alternate dimension tolerance value
(vla-put-AltSuppressTrailingZeros dimObj (if (= originalValue :vlax-true) :vlax-false :vlax-true))
(setq newValue (vla-get-AltSuppressTrailingZeros dimObj))
(alert "Toggling the display of trailing zeros in the alternate dimension to original value.")
(vla-put-AltSuppressTrailingZeros dimObj (if (= newValue :vlax-true) :vlax-false :vlax-true))
GMT+8, 2026-10-28 11:50
