AltRoundDistance 属性 (ActiveX)
指定备用单位的舍入。 支持的平台:仅限 Windows 签名VBA: object.AltRoundDistance
属性值只读:不 类型:双 一个正实数,表示要将距离舍入到的值。初始值为 0.00。 言论如果该属性处于打开状态,则此属性将定义要将距离舍入到的数字。AltUnits 注意:此属性将覆盖给定维度的 DIMALTRND 系统变量的值。
例子VBA: Sub Example_AltRoundDistance()
' uses AltRoundDistance to set the alternate unit display
' of the dimension to rounded values
Dim dimObj As AcadDimAligned
' Define the dimension
point2(0) = 10.123: point2(1) = 5: point2(2) = 0
' Enable alternate unit display
dimObj.AltUnits = True
MsgBox "Press any key to round the alternate dimension unit display to .5"
' Round the distance of the alternate dimension to 0.50 of a unit
dimObj.AltRoundDistance = 0.5
MsgBox "Alternate dimension units have been rounded to: " & dimObj.AltRoundDistance
可视化 LISP: (vl-load-com)
(defun c:Example_AltRoundDistance()
;; uses AltRoundDistance to set the alternate unit display
;; of the dimension to rounded values
;; Define the dimension
point2 (vlax-3d-point 10.123 5 0)
;; Enable alternate unit display
(vla-put-AltUnits dimObj :vlax-true)
(vla-ZoomAll acadObj)
(alert "Round the alternate dimension unit display to .5")
;; Round the distance of the alternate dimension to 0.50 of a unit
(vla-put-AltRoundDistance dimObj 0.5)
(alert (strcat "Alternate dimension units have been rounded to: " (rtos (vla-get-AltRoundDistance dimObj) 2 4)))
GMT+8, 2026-10-27 13:31
