AltFontFile 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 594| 评论: 0|原作者: admin|来自: AutoCAD
指定如果 AutoCAD 找不到原始字体且未在字体映射文件中指定备用字体时要使用的字体文件的位置。
object.AltFontFile
类型:PreferencesFiles
此属性应用于的对象。
只读:不
类型:字符串
备用字体文件。
Sub Example_AltFontFile()
    ' AltFontFile. It then changes the value, and finally
    Dim currAltFontFile As String
    Dim newAltFontFile As String
    Set preferences = ThisDrawing.Application.preferences
    ' Retrieve the current AltFontFile value
    currAltFontFile = preferences.Files.AltFontFile
    MsgBox "The current value for AltFontFile is " & currAltFontFile, vbInformation, "AltFontFile Example"
    ' Change the value for AltFontFile
    newAltFontFile = "C:/AutoCAD/Fonts/gothice.shx"
    preferences.Files.AltFontFile = newAltFontFile
    MsgBox "The new value for AltFontFile is " & newAltFontFile, vbInformation, "AltFontFile Example"
    ' Reset AltFontFile to its original value
    preferences.Files.AltFontFile = currAltFontFile
    MsgBox "The AltFontFile value is reset to " & currAltFontFile, vbInformation, "AltFontFile Example"
(defun c:Example_AltFontFile()
    ;; AltFontFile. It then changes the value, and finally
    (setq files (vla-get-Files preferences))
    ;; Retrieve the current AltFontFile value
    (setq currAltFontFile (vla-get-AltFontFile files))
    (alert (strcat "The current value for AltFontFile is " currAltFontFile))
    ;; Change the value for AltFontFile
    (setq newAltFontFile "C:/AutoCAD/Fonts/gothice.shx")
    (vla-put-AltFontFile files newAltFontFile)
    (alert (strcat "The new value for AltFontFile is " newAltFontFile))
    ;; Reset AltFontFile to its original value
    (vla-put-AltFontFile files currAltFontFile)
    (alert (strcat "The AltFontFile value is reset to " currAltFontFile))
GMT+8, 2026-10-28 17:44
