AlignmentPointAcquisition 属性 (ActiveX)
指定如何获取自动对齐点。 支持的平台:仅限 Windows 属性值只读:不 类型:枚举acAlignmentPointAcquisition
言论此属性的初始值为 。acAlignPntAcquisitionAutomatic 例子VBA: Sub Example_AlignmentPointAcquisition()
' This example reads and modifies the preference value that controls
' how AutoAlignment points are acquired. When finished, this example resets
' the preference value back to its original value.
Dim ACADPref As AcadPreferencesDrafting
' Get the drafting preferences object
Set ACADPref = ThisDrawing.Application.preferences.Drafting
originalValue = ACADPref.AlignmentPointAcquisition
MsgBox "The AlignmentPointAcquisition preference is: " & originalValue
' Toggle and display the AlignmentPointAcquisition preference
If ACADPref.AlignmentPointAcquisition = acAlignPntAcquisitionAutomatic Then
ACADPref.AlignmentPointAcquisition = acAlignPntAcquisitionShiftToAcquire
Else
End If
newValue = ACADPref.AlignmentPointAcquisition
MsgBox "The AlignmentPointAcquisition preference has been set to: " & newValue
' this preference in effect
ACADPref.AlignmentPointAcquisition = originalValue
MsgBox "The AlignmentPointAcquisition preference was reset back to: " & originalValue
可视化 LISP: (vl-load-com)
(defun c:Example_AlignmentPointAcquisition()
;; This example reads and modifies the preference value that controls
;; how AutoAlignment points are acquired. When finished, this example resets
;; the preference value back to its original value.
;; Get the drafting preferences object
(setq ACADPref (vla-get-Drafting (vla-get-Preferences acadObj)))
(setq originalValue (vla-get-AlignmentPointAcquisition ACADPref))
(alert (strcat "The AlignmentPointAcquisition preference is: " (itoa originalValue)))
;; Toggle and display the AlignmentPointAcquisition preference
(if (= (vla-get-AlignmentPointAcquisition ACADPref) acAlignPntAcquisitionAutomatic)
(vla-put-AlignmentPointAcquisition ACADPref acAlignPntAcquisitionShiftToAcquire)
(vla-put-AlignmentPointAcquisition ACADPref acAlignPntAcquisitionAutomatic)
(setq newValue (vla-get-AlignmentPointAcquisition ACADPref))
(alert (strcat "The AlignmentPointAcquisition preference has been set to: " (itoa newValue)))
;; this preference in effect
(vla-put-AlignmentPointAcquisition ACADPref originalValue)
(alert (strcat "The AlignmentPointAcquisition preference was reset back to: " (itoa originalValue)))
GMT+8, 2026-10-27 21:28
