ADCInsertUnitsDefaultTarget 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 703| 评论: 0|原作者: admin|来自: AutoCAD
确定要自动用于设计中心中对象的单位,以用于未分配插入单位的目标图形。
object.ADCInsertUnitsDefaultTarget
类型:PreferencesUser
此属性应用于的对象。
只读:不
类型:枚举acInsertUnits
  • acInsertUnitsAngstroms
  • acInsertUnitsAstronomicalUnits
  • acInsertUnitsCentimeters
  • acInsertUnitsDecameters
  • acInsertUnitsDecimeters
  • acInsertUnitsFeet
  • acInsertUnitsGigameters
  • acInsertUnitsHectometers
  • acInsertUnitsInches
  • acInsertUnitsKilometers
  • acInsertUnitsLightYears
  • acInsertUnitsMeters
  • acInsertUnitsMicroinches
  • acInsertUnitsMicrons
  • acInsertUnitsMiles
  • acInsertUnitsMillimeters
  • acInsertUnitsMils
  • acInsertUnitsNanometers
  • acInsertUnitsParsecs
  • acInsertUnitsUnitless
  • acInsertUnitsUSSurveyFeet
  • acInsertUnitsUSSurveyInch
  • acInsertUnitsUSSurveyMile
  • acInsertUnitsUSSurveyYard
  • acInsertUnitsYards
此属性的初始值为 。acInsertUnitsUnitless
注意:此属性的值存储在 INSUNITSDEFTARGET 系统变量中。
Sub Example_ADCInsertUnitsDefaultTarget()
    ' This example reads and modifies the ADCInsertUnitsDefaultTarget
    ' preference value.
    ' When finished, this example resets the preference value back to
    ' its original value.
    Dim ACADPref As AcadPreferencesUser
    Dim originalValue As Integer, newValue As Integer
    ' Get the user preferences object
    Set ACADPref = ThisDrawing.Application.preferences.User
    originalValue = ACADPref.ADCInsertUnitsDefaultTarget
    MsgBox "The ADCInsertUnitsDefaultTarget preference is set to: " & originalValue
    ' Modify the ADCInsertUnitsDefaultTarget preference by toggling the value
    ACADPref.ADCInsertUnitsDefaultTarget = acInsertUnitsMillimeters
    MsgBox "The ADCInsertUnitsDefaultTarget preference has been set to: " & ACADPref.ADCInsertUnitsDefaultTarget
    ACADPref.ADCInsertUnitsDefaultTarget = originalValue
    MsgBox "The ADCInsertUnitsDefaultTarget preference was reset back to: " & originalValue
(defun c:Example_ADCInsertUnitsDefaultTarget()
    ;; This example reads and modifies the ADCInsertUnitsDefaultTarget
    ;; preference value.
    ;; When finished, this example resets the preference value back to
    ;; its original value.
    ;; Get the user preferences object
    (setq pref (vla-get-Preferences acadObj))
    (setq user (vla-get-User pref))
    (setq originalValue (vla-get-ADCInsertUnitsDefaultTarget user))
    (alert (strcat "The ADCInsertUnitsDefaultTarget preference is set to: " (itoa originalValue)))
    ;; Modify the ADCInsertUnitsDefaultTarget preference by toggling the value
    (vla-put-ADCInsertUnitsDefaultTarget user acInsertUnitsMillimeters)
    (alert (strcat "The ADCInsertUnitsDefaultTarget preference has been set to: " (itoa (vla-get-ADCInsertUnitsDefaultTarget user))))
    ;; Restore the preference back to its original value
    (vla-put-ADCInsertUnitsDefaultTarget user originalValue)
    (alert (strcat "The ADCInsertUnitsDefaultTarget preference was restored back to: " (itoa originalValue)))
GMT+8, 2026-10-27 14:27
