ActiveSpace 属性 (ActiveX)
2024-5-18 17:52| 发布者: admin| 查看: 734| 评论: 0|原作者: admin|来自: AutoCAD
在图纸空间和模型空间之间切换活动空间。
object.ActiveSpace
类别: 文档
此属性应用于的对象。
只读:不
类型:枚举acActiveSpace
  • acModelSpace
  • acPaperSpace
对于模型空间浮动视口,此值设置为 。即使您具有编辑模型的能力,从技术上讲,您仍然处于纸张空间中。acPaperSpace
有关此属性的更多信息,请参见对象。PViewport
注意:此属性的值存储在 TILEMODE 系统变量中。
Sub Example_ActiveSpace()
    ' This example toggles the ActiveSpace property from
    ' paper space to model space.
    ' Display the current setting for TILEMODE
    MsgBox "TILEMODE = " & ThisDrawing.ActiveSpace, vbInformation, "ActiveSpace Example"
    ' Changes active document to paper space
    ThisDrawing.ActiveSpace = acPaperSpace
    ' Changes active document to model space
    ThisDrawing.ActiveSpace = acModelSpace
(defun c:Example_ActiveSpace()
    ;; This example toggles the ActiveSpace property from
    ;; paper space to model space.
    ;; Display the current setting for TILEMODE
    (alert (strcat "TILEMODE = " (itoa (vla-get-ActiveSpace doc))))
    ;; Changes active document to paper space
    (vla-put-ActiveSpace doc acPaperSpace)
    ;; Changes active document to model space
    (vla-put-ActiveSpace doc acModelSpace)
GMT+8, 2026-10-27 16:05
