ActivePViewport 属性 (ActiveX)
指定图形的活动图纸空间视口。 支持的平台:仅限 Windows 言论必须先使用此属性将视口设置为活动状态,然后才能看到对其所做的任何更改。 例子VBA: Sub Example_ActivePViewport()
Dim newPViewport As AcadPViewport
Dim height As Double
Dim width As Double
height = 5#
width = 5#
centerPoint(0) = 5#: centerPoint(1) = 5#: centerPoint(2) = 0#
' Create a paper space Viewport object
ThisDrawing.ActiveSpace = acPaperSpace
Set newPViewport = ThisDrawing.PaperSpace.AddPViewport(centerPoint, width, height)
ZoomAll
newPViewport.DISPLAY (True)
' Before making a paper space Viewport active,
' the mspace property needs to be True
ThisDrawing.mspace = True
ThisDrawing.ActivePViewport = newPViewport
可视化 LISP: (vl-load-com)
(defun c:Example_ActivePViewport()
(setq centerPoint (vlax-3d-point 5 5 0)
height 5.0
width 5.0)
;; Create a paper space Viewport object
(vla-put-ActiveSpace doc acPaperSpace)
(setq paperSpace (vla-get-PaperSpace doc))
(setq newPViewport (vla-AddPViewport paperSpace centerPoint width height))
(vla-ZoomAll acadObj)
(vla-Display newPViewport :vlax-true)
;; Before making a paper space Viewport active,
;; the mspace property needs to be True
(vla-put-MSpace doc :vlax-true)
(vla-put-ActivePViewport doc newPViewport)
GMT+8, 2026-10-27 21:27
