ActiveProfile 属性 (ActiveX)
指定 AutoCAD 任务的活动配置文件。 支持的平台:仅限 Windows 属性值只读:不 类型:字符串 活动配置文件的名称。 言论没有其他评论。 例子VBA: Sub Example_ActiveProfile()
' ActiveProfile.
Dim currActiveProfile As String
Set preferences = ThisDrawing.Application.preferences
' Retrieve the current ActiveProfile value
currActiveProfile = preferences.Profiles.ActiveProfile
MsgBox "The current value for ActiveProfile is " & currActiveProfile, vbInformation, "ActiveProfile Example"
可视化 LISP: (vl-load-com)
(defun c:Example_ActiveProfile()
;; ActiveProfile.
;; Retrieve the current ActiveProfile value
(setq currActiveProfile (vla-get-ActiveProfile (vla-get-Profiles preferences)))
(alert (strcat "The current value for ActiveProfile is " currActiveProfile))
GMT+8, 2026-10-26 18:25
